IPC6023 ERROR
Brian1966
Message 11 of 11
Just recently upgraded to Fibre. All good apart from the fact that I am getting an IPC 6023 ERROR on my entertainment pack channels. Netflix and Players working fine.
Have tried software update and resetting the box but still no joy. Any advice appreciated
Brian
10 REPLIES 10
Message 1 of 11
Hi Brian1966
Our Network Team have asked us to arrange a TalkTalk engineer visit to complete further investigations.
Message 2 of 11
Hi Brian1966
I've escalated this fault over to our Network Team and I will post back on this thread as soon as I receive further information.
Message 3 of 11
Hi Michelle,
Sorry for delay in replying.
Yes all new cables used and still getting error message IPC6023.
Brian
Message 4 of 11
Hi Michelle,
Brian
Message 5 of 11
Hi Brian,
I'm sorry for the delay. Did you use all the new cables that came with the new TV box? Are you still seeing the same error since your last post?
Message 6 of 11
Hi Karl,
New Tv box arrived today so thank you for that. Really had high hopes but unfortunately the problem remains.
You have been absolutely brilliant so far so any further help appreciated.
Brian
Message 7 of 11
Hi @Brian1966
Multicast engineer has been out - all ok from Openreach side.  Circuit ID's match and traffic can be seen at the port.
I've re-ran all tests here and all still clear.
I can see you have a new wifi hub about 3 weeks ago.  A new TV box is on the way so this can be ruled out.
Message 8 of 11
All tests are clear.  I've arranged an Openreach Multicast engineer to go to the exchange and confirm IPTV traffic can be seen from there. I'll let you know what they find.
Message 9 of 11
Hi Karl and thanks for reply.
Router has been turned off for 30 minutes plus.
On demand boost content does play.
TV box direct with cable.
Phone line clear.
Thank you for any help you can provide
Brian
Message 10 of 11
Has this error only started from 28th Aug after the upgrade was completed ?
Have you tried turning the router off for 30 minutes to clear the session ?
If you go to MORE TV and select some on demand content from a boost channel such as Sky 1 etc, does this play ?
Is the TV box direct to the router with a cable ?
Check the home phone, does this have a clear dial tone ?
