IPTV appears to be blocked
generalg
Message 8 of 8
Hi, I'm having trouble connecting my IPTV using my fibre connection.
I'm certain all other settings are correct as I can access the same services using my phone, switching over to wifi means it cuts out and cannot reconnect.
Does TalkTalk support IPTV? Or are there any restrictions on my account perhaps?
Cheers
7 REPLIES 7
Message 1 of 8
I've a different model router on the way so this can be tested.
Message 2 of 8
Hi I’ve tried that too but doesn’t seem to work
Message 3 of 8
You could try a pin reset of the router.
Message 4 of 8
Hi, I tried this, which worked for a period of time, however, the same problem has occurred again, and trying to do the same on/off trick  again has resulted in no success this time.
Any ideas?
Thanks in advance
Message 5 of 8
Hi generalg,
I'm sorry for the delay. How are you getting on?
Message 6 of 8
I’ll try that when I get in from work! Failing that is there anything else to try?
cheers
Message 7 of 8
Hi generalg,
Have you tried switching the router off for a full 30 minutes and then tested this again?
