on 28-11-2017 08:49 PM
Just bought XBOX One X and changed my Talk Talk package to get the fastest Fibre speed, Connection was dropping. Xbox network setting say I should be on IPV6 rathan IPV4 but dont know if it is yet supported by Talk Talk. Please advise as I have an XBOX One X that keeps dropping connection and I shall be forced to look at another ISP.
30-01-2019 09:07 AM - edited 30-01-2019 09:08 AM
You've bought an incorrect device. The smaller plug is for DSL connection and requires a VDSL modem router (or home gateway). What you appear to have purchased is a cable router (or just router). That is not capable of connsectin to the BT socket at all. My suggestion would be to get a refund and purchase a home gateway (or stick with the Talktalk router). At the moment, it's pointless buying an ipv6 capable router as Talk talk are still ipv4 and are not showing us any indication as to when they might provide an ipv6 service...
on 29-01-2019 10:30 PM
I've bought a new router which supports IPV6 as recommended but can't connect the internet cable into the back of it! The connection coming from the BT box on the wall is a smaller size than the ethernet size socket in the back of the router. I think the smaller plug size is RJ11 going into a RJ45 socket (this doesn't affect my existing TalkTalk router which takes this smaller plug size). I bought an adaptor which has the smaller plug end and a socket I can put an ethernet cable into to allow me to put the other end of the ethernet cable into my router - but it won't acknowledge the connection. Help!
on 17-12-2018 07:24 PM
hey steve im a talktalk user myself hes the best advice you can get from someone who knows tecknology instead of amateurs. the reason you cant connect wifi without disconnecting is because talktalk do not support IPv6 at all. even if sent another one of their routers its just gonna end up being the same result the best option for you bud is to just buy your own router thats IPv6 compatible after that you will be fine i had the same result before and changed the router now i dont have a poblem at all with the wifi at home anymore. This is the router I bought and IPv6 ready https://www.amazon.co.uk/TP-Link-AC1750-Dualband-Zertifiziert-General%C3%BCberholt/dp/B00BUSDVBQ/ref...
on 20-09-2018 10:22 AM
Hi spike6511,
Please can you create your own thread and we can look into this further for you.
on 19-09-2018 02:35 PM
Hi, thanks for tthe information, I am using the said router you hav talked about and you reckon that this needs an firmware update..
on 30-01-2018 07:53 PM
A different router is on the way to see if this gives better wifi coverage.
on 30-01-2018 06:37 PM
Thanks Karl,I have mentioned time and time again that the WiFi keeps dropping. I have a Desktop using an ethernet cable into the router and the speed on that is fine. I have an Xbox, Now tv box, and phone on wifi and when the Wifi goes they all go. It only goes off for a few minutes but I have to mess around with resetting router or changing the channel on my network.
If you think that a different router will solve it then yes I would like a different router.
on 30-01-2018 03:01 PM
Hi Steve2409
line is in sync at 80mb with no errors showing. Are the drops mostly affecting Wifi ?
Would you like to try a different model router ?
on 29-01-2018 08:02 PM
Had just about enough now, why am I paying £35 pounds a month for such shoddy service. Just been on the phone to talk talk for 14mins and got cut off, fed up now I will change my provider. VERY DISAPPOINTED TALK TALK.
on 29-01-2018 07:36 PM
I know exactly how you feel. HG633 awful Wi-Fi. I suffered all your issues re Xbox too, and losing 5ghz. The router update to v1.22.1t was meant to solve it- but didn’t. I tried all the fixes recommended on here re changing channels, etc on router, still same issues.
I just turned Wi-Fi off on the TalkTalk router and use an old Apple AirPort Extreme for Wi-Fi routing. Solid and fast connection- 10mbps faster.
You’ll just go in circles on this forum, as they'll never admit how poor the supplied equipment is. I’d recommend cutting your losses and getting a different router.
PS I noticed there’s still no clarity re IPV 6.
on 29-01-2018 05:13 PM
on 15-12-2017 11:04 AM
Hi Steve2409,
I'm sorry to hear this. Just to confirm, did you try a few different wireless channels to see how the connection compares? Do you have an alternative router that you could test with to see how it compares?
on 14-12-2017 08:08 PM
ok after a couple of days of testing, ran speed test on my desktop and getting 74mbs/18mbs but xbox 1 x the wifi keeps dropping. I have a Now tv box as well and it is dropping also. pc is ethernet connection but every thing else is wifi??
Steve
on 12-12-2017 02:50 PM
Hi Steve
Thank you, please let us know how you get on.
on 12-12-2017 02:26 PM
Thanks Debbie, I will have a look when I get home from work.
Steve
on 12-12-2017 02:16 PM
Hi Steve
In regards to changing the wireless channels, please see the below help page for further information.
How do I change my wireless channel
on 12-12-2017 01:41 PM
Hi Michelle, Have not changed channels because I dont know how to on talk talk I knew how to on Virgin but it seems to be a bit more complicated on Talk Talk.
Wired connection is fine.
Steve
on 12-12-2017 12:22 PM
Hi Steve2409,
Have you recently tried a few different wireless channels to see how the connection compares? Does the wired connection seem stable?
on 12-12-2017 09:26 AM
Hi Chris, noticed wifi connection is really bad lately. Xbox is WiFi, desktop is ethernet cable.
on 12-12-2017 09:12 AM
Hi Steve2409,
You're router has the latest firmware version.
How does you xbox connect to your router, Ethernet cable or Wifi?
Does your internet connection seem stable except for the xbox issue?
