on 03-09-2020 01:30 PM
Hi, I've just taken receipt of my TalkTalk router (DG8041W) and I need to set up a device. It requires Port 80 and 2165 UDP open.
The device is a SALUS IT500 gateway connector.
I've read the Port Forwarding document but seem to be able to figure what to enter. Can anyone help please.
on 04-09-2020 10:31 AM
Hi Nottmsouthc,
I can see that Keith kindly offered you assistance with this, please let us know how you get on
on 03-09-2020 02:50 PM
You will not be able to forward TCP port 80 as that is used by the router, I have requested that this is changed as the router does not actually use it. There is a workaround I have developed which is to use a different external port & translate that in the rule to TCP port 80 within the rule.
If you want further help, then please include a screenshot of what you have tried in the router.
