IPv6
Jehenry2
Message 3 of 3
I am now into the 4th hour of finding an answer to the question: how do I connect my xbox via IPv6? If anyone from the community can help it would be most appreciated as talktalk do not seem to employ anyone with the ability to answer it.
My router is a Huawei HG633.
Chris-TalkTalk
Message 1 of 3
Hi Jehenry2 ,
Sorry I can't help you either, can I ask why you want to connect it via IPv6?
Divsec
Message 2 of 3
Hi Jehenry I think you will find that TT don't support IPv6. Your post has been flagged for assistance so hopefully the team will get back to you soon. They only work office hours so it might be Monday before you get a definitive answer.
Sorry to be so negative on you First post.
