ISP Login and Password
Allenout
Message 3 of 3
I am moving to a new modem and router as my TalkTalk one is too slow, one of the things that I need is the ISP Login and Password to enable them. This is fundamentally different than the Wifi Hub login and password so does anyone know how to get it?
FritzCT
Wise Owl
Message 1 of 3
The most important bit is that you need to select "Dynamic IP", "Ipoe", or something similar. You don't need your username & password as that's not how TT identify the connection.
What is the 3rd party unit you wish to connect.
Fritz
Skynet_TX
Message 2 of 3
