ISP Username and Password
martinsandman1
Message 3 of 3
Hi All,
I'm intending to setup another router in my house to replace the TalkTalk Hub SG4K10002816t
I need to find my ISP username and password?
Any idea where I can find this? I've tried in the Hub portal itself but I didn't have much luck
Many thanks
Martin
Martin Sandford
Chris-TalkTalk
Message 1 of 3
Hi Martin,
I can see that Keith has answered you question, please let us know if you need any further assistance
Message 2 of 3
TalkTalk routers no longer use this, it is done at the network level now & is based on if your landline number is allowed to connect to the TalkTalk network or not. Now, just because you do not need these details anymore, doesn't mean that the replacement router you have will let you leave the fields blank, as they can often be compulsory.
Just put whatever you like in for the username & password & you should be OK.
