Incoming port 80/443
Ligan
Message 27 of 27
Having some issues with fibre and and not receiving data even though port 80 is forwarded correctly so I just wanted to check if anyone else has had an issue with a webbserver and port 80 or if talk talk block this? Cheers
26 REPLIES 26
Piethorne
Chat Champion
Message 1 of 27
It can take a few minutes for changes to propagate through nameservers. I've set up webservers on VMs using non-standard binding ports and forwarded ports + masked / redirected URLs before, and have sometimes had enough time to make a brew and clear out browser caches before the URLs became active.
I'm just a customer who might be able to help, not official help & support.
Message 2 of 27
I think I was just being impatient, it has worked and now everything is working as intended! What a sigh of relief.
Message 3 of 27
I do not have Nginx proxy to try, so sorry I can't help you where that is concerned.
Message 4 of 27
I've just tried this but unfortunately didn't work, I went to Local DNS > DNS Records and entered my website address and the ip for Nginx proxy that it's on 192.168.1.254 is that right?
Message 5 of 27
Hi @Ligan
Just out of interest, I have now got a Linux Mint running in a VM with Oracle VirtualBox and have forwarded FTP to a server on there & it all worked even with the Linux Firewall configured.
Message 6 of 27
Very few TT routers support NAT loopback - I didn't realise you were trying to test it like that. Drop the WiFi connection on a smartphone & use mobile data is a very good way to test it.
Message 7 of 27
The port forwarding is working so thank you for all your help Keith, you've been great. As per the commenter above the router doesn't seem to support NAT Loopback so I'll set up pihole again and add a DNS entry for the website
Message 8 of 27
Perfect, thank you i'll get that sorted
Message 9 of 27
I ran into this problem...  it's because the Sagemcom router doesn't support NAT loopback.
You mentioned you use pi-hole - the fix for me was to add a DNS entry for the external address in the 'Custom DNS' section, and point it to your local LAN IP address for the site (192.168.1.240).
Message 10 of 27
So are you saying that the port forwarding is OK now, or is it that Wireshark is working? If the former, there is no need for me to see your trace.
When in your VM, do not forget that you will need to connect to port 8091.
Message 11 of 27
Hi Keith,
sent a couple messages last night and also tried to private message you. I just had to run it as  sudo and I got the trace, can upload tonight if needed but .... I THINK IT WORKS!
So stupidly I never actually tried to connect outside to the websites outside of my network.  They do appear correctly it's just that when I'm inside my own network I can't connect to them. From what I've been trying to read up on it could be something to do with the router and maybe having to move to split dns or I have to edit the dns server to add the website and associate it with its internal IP.
Not sure how to do either of those things or which one is correct mind you.
Message 12 of 27
None of those are showing any activity, so Wireshark will not be able to capture on them. What interfaces are listed on the VM's OS?
Message 13 of 27
Not sure which of these interfaces to run it on, any ideas? Cheers!
Message 14 of 27
I will edit your post to remove the screenshot as it gives away your name & the company you work for. I will delete the trace as well to protect your privacy.
Run Wireshark on the VM itself, the interface that Wireshark needs to be set to capture on is the network adapter in the VM. What is the IP address of the device you are trying to forward to & is it still TCP port 8091?
Message 15 of 27
Hi Keith,
Wireguard server is on the same VM as Nginx, vm is set to use vmbr0 which is a virtual bridge. I've run wireshark while I'm connected through my VPN at another location, presume that should still have the same data as it's routed through my home network.
I also wasn't sure which of the below options to select so I just went with "Ethernet"
Hope this helps! Thank you
edit : in hindsight I don't think this info will be any good, I'll run it again when I get home tonight
Message 16 of 27
Is Wireguard on the host or the VM, if the VM & you can now forward a port to that, anything else would seem like it would be down to the application.
However, Wireshark will enable me to prove what is going wrong, I will PM you with details on how to use it.
Please can you confirm what mode the VM's network adapter is configured as.
demulv
Message 17 of 27
Are you able to open the site from your internal network using http://192.168.1.240:8091 ?
Message 18 of 27
Thank you for your help so far by the way Keith.
I've re-done the VM entirely, reset my DNS back, removed my PiHole and started from scratch. I've installed Wireguard and forward the port for that and can confirm that works all okay.
I've redone the port forwarding rule for the web server and kept it just on port 80 and I've set it as TCP-UDP instead of just TCP.
Port 80 and 443 are showing as open in portcheck tool
The websites themselves  are on Freenom and Bluehost.
I've got one trying to point with a CNAME record to my dynamic DNS No-IP and I've got 2 free ones on freenom trying to point using A records to my dynamic ip which I know will change but I just wanted to see if there was an issue with the dynamic dns system.
I've installed Wireshark but I'm not quite sure how to use it, is there a specific test you'd like me to run on it?
Message 19 of 27
No there is nothing wrong with the port forwarding on the router at all. This is what I have just replicated:-
Testing port 80 (with 8091 open on my PC) reports open:-
When port forwarding to a VM, you must look carefully at your VM's networking configuration. When I have used VirtualBox, you have to set the VM's networking configuration into Bridged Mode, if you want to port forward to it. This gives the VM an IP address on the same subnet and you can then forward to that address from the port forwarding rule on the router.
Can you run Wireshark on the VM, if so get me a trace from that & I will check it for you?
Message 20 of 27
Webserver is running in a docker container on an Ubuntu VM inside Proxmox.
I've just changed the port forwarding rule to translate port 80 to 8091 and push to 192.168.1.254 which is the ubuntu VM itself but still noting. Port check tool is showing nothing listening on 80
I'm convinced it's a port forwarding issue since I can access the webserver/reverse proxy internally just not externally.
No installed firewall other than whatever is be default on the router
