Installation process
edallen
Whizz Kid
Message 11 of 11
HI,
Just been booked into have the upgrade to fibre 150 and been reading the installation process. I just want to know what will exactly happen on the day? what is installed and how? will the engineer be making any changes to the wall of the property for example creating a new phone socket connection in a new location on the wall?
10 REPLIES 10
Message 1 of 11
I can't see it being necessary but the engineer will be able to discuss the requirements and options available
Message 2 of 11
thanks, i live a rented property and just need to know if the engineer will have to making holes in the wall, hopefully this is not neccessary
Message 3 of 11
Hi edallen,
martswain has pretty much covered it there 🙂
martswain
Message 4 of 11
@edallen
The answers are in the article in post #2
The engineer will assess what is needed on the day.
They will probably replace your master socket with a g.fast version with two outlets, one for broadband and one for phone.
They will install an modem close to the master socket which will need a power point nearby.
That modem will connect to your router via a LAN cable, the cable will normally be around 1.5 to 2 metres.
Message 5 of 11
either nte 5 or nte 5c, it has the old bt logo on it.
i just want answers to my questions in the original post
Message 6 of 11
Hi edallen,
Which type of master socket do you have? - Your guide to master sockets
Message 7 of 11
just says fibre 150
martswain
Message 8 of 11
@edallen  there are two products that have 150 in their names, one is over the phone line (as in @Michelle-TalkTalk 's link) and the other is Future Fibre 150 - Data Only, which is full fibre to the home.
Which one have you ordered ?
The two have different installation requirements.
edallen
Whizz Kid
Message 9 of 11
Yes i have read that, still not sure
Message 10 of 11
Can I just confirm, have you seen the below Help Guide?
Your Fibre 150/250 installation
