Interleaving
Mannh
Chat Champion
Message 4 of 4
Since setting up my new fibre kit there are interleaving stats of 247 Upstream and 1716 Downstream. It was never this bad with the old router I’m just wondering what’s gone wrong?
3 REPLIES 3
Message 1 of 4
Hi Mannh,
Ok thanks for letting me know. Have you tried a few different wireless channels to see how the stability compares? Is the connection stable if you connect wired? Which router are you currently using? Did you replace the original router due to the wireless issue?
Mannh
Chat Champion
Message 2 of 4
Hi Michelle,
Although I’ve replaced the router, the WiFi still drops out from time to time. Interleaving isn’t a problem if it doesn’t affect the speed. It just seemed very much higher than the previous router.
Message 3 of 4
Hi Mannh,
I've run a test on the line which hasn't detected a fault and the connection stats look ok. Just to confirm, are you experiencing any issues with the performance of the connection?
