Intermittent Drop-outs
holbrookian
Message 8 of 8
In the last week our broadband (FTTC) service has started to suffer from intermittent pauses. This is most noticeable when streaming to a smart TV where the picture freezes for several seconds then picks up again. I have also noticed it occasionally when downloading to a PC and once during a speed test when the upload part of the test failed to complete.
The TV and PC are connected using TP Link power line adapters rather than WIFi.
The router shows a steady connection at about 62 Mbps (noise margin of 3.0 db) and the TP Link software reports more than adequate connection speeds of 250 to 300 Mbps. There are only 2 of us in the house so there is no internal contention for capacity.
On the TV, the 'pauses' occur even with low bit rates (e.g. 2.5 Mbps). Conversely, UHD content at 15 Mbps is normally fine with no pixelation.
Since the speed problem is noticeable with wired connections, I presume this is an external issue.
Perhaps you could offer some advice on how to resolve it.
By the way, I haven't found a way to do a speed test to a wired device on the TalkTalk service status page.  I used the thinkbroadband test.
Many thanks in advance!
APS
7 REPLIES 7
Message 1 of 8
No Problem 🙂 Just post back here when you need us.
Message 2 of 8
Sorry for delay in responding - been a bit tied up. Can I please take a 'rain check' on the offer of a different router as I have some more checks to carry out inside my home? Some preliminary tests point to the intermittent slow-downs being caused by electrical interference affecting the TP Link powerline adapters on one circuit. They had been rock-solid for over 18 months.
I will contact TalkTalk again if the needed.
Also, I would like to say that I have been very happy with the broadband from TalkTalk. It has been more reliable and delivered a higher speed (over 10%) compared with the previous provider (who should remain nameless). Another grouse I had with them was the routine automatic reboots of the router even during daytime hours.
APS
Message 3 of 8
Hi holbrookian
I've completed a line test which hasn't detected any faults, would you like me to send a different router for testing to see how the connection compares?
holbrookian
Message 4 of 8
Thanks for reply. Profile now updated with phone numbers etc. as requested. Away at the moment so I won't be able to carry out tests, monitoring until Friday evening.
APS
Chris-TalkTalk
Message 5 of 8
Hi holbrookian,
  • Name
  • Telephone number
  • Alternative contact number
holbrookian
Message 6 of 8
No, the router does not reboot (which normally takes quite some time) and the pause/drop out is from seconds to about a minute.
Last night when watching a Netflix HD stream the bit rate shown by Netflix dropped from 2.5 Mbps to 0.16 Mbps for a minute or so. It was noticeable due to blocky pixels.
APS
Message 7 of 8
When the connection drops, does it come back up on its own again without rebooting the router ?
Do the lights on the ont remain lit.
