Intermittent broadband
ToneTone
Message 10 of 10
I have a SageCom FAST 5364 router and typically get speeds of around 37 Mb/s download.
Several times each day however the connection drops - sometimes for 10 minutes or more. I now have a routine of logging onto the router, going to the "Internet Settings" page and then I see the red 'X' on the connectivity diagram change to a green tick, after which all is ok again.
My perception is that this in increasing in frequency.
What can I do?
Tony
9 REPLIES 9
Message 1 of 10
No yet.  There may be one later when the logistics teams have updated the account.
Message 2 of 10
many thanks. Is there a tracking number available?
regards
tonetone
Message 3 of 10
A replacement router is on the way to you.
Message 4 of 10
Hi Michelle
That would be great, many thanks.
ToneTone
Message 5 of 10
Hi Tony,
Ok, would you like us to send a replacement router for testing purposes to rule this out?
Message 6 of 10
Hi Michelle
Unfortunately not.  I have plugged the router directly into the master socket, although I thing the problem is on the house side of the router, not the street.  No difference in behaviour.
Tony
Message 7 of 10
Hi ToneTone,
I'm sorry to hear this. Do you have an alternative router that you could test with to rule this out?
Message 8 of 10
Hi Michelle
The problem is less frequent at the moment, but still exists.
As an example, it dropped around 0931 this morning on a wired connection.  It restarted when I logged onto the router, and went to the Internet Settings page where I could see the right-hand ‘X’ change to a green tick after a few seconds.  When that happened, everything started working again.
It feels like I have a defective router that drops its wired and wireless connections periodically.
ToneTone
Message 9 of 10
Hi ToneTone,
I'm sorry for the delay. I've run a test on the line which hasn't detected a fault and the connection looks stable for the last 5 days. Just to confirm, has the connection remained stable since your last post?
Does this affect wired and wireless?
