Internet Connection Keeps Dropping
Genyz
Message 12 of 12
Hi all, for the past 6-8 weeks I’m having to reset my router every few days as I get no connection. This is both wired and wireless, the light displays white and after a reboot it works fine.
has anybody else come across this or got some tips? When I run the service checker it always shows no issues so I’m thinking the router could be on the way out after a much higher demand from everyone being at home. It’s a Sagem router if that’s of any use?
11 REPLIES 11
Message 1 of 12
Hi Genyz
That's great, thanks for letting us know 🙂
Message 2 of 12
Hi Debbie. Sorry for the delay, I have the router and it’s been working brilliantly for a week now.
Message 3 of 12
Hi Genyz
Message 4 of 12
Hi @Lilibut68
Please can you create a new topic on the Community, we can then look into this for you.
Message 5 of 12
Looking through other posts, it seems to be an issue at the moment. I had mine for a couple of years before this without a problem though.
Message 6 of 12
Hi Genyz
The Huawei WIFI hub is on its way, please allow 24-48hrs for this to arrive.
Debbie 🙂
Message 7 of 12
I think im having the same issue.  I have that router and am experiencing slow speed and regular drop out.
I've only been a talk talk customer for a month and its not impressing me so far I have to say
Can someone please suggest something
Message 8 of 12
Hi Debbie
That would be brilliant, thank you!
Message 9 of 12
Hi Genyz
Apologies for this.
Would you like me to send a Huawei WIFI hub for testing to see how the connection compares?
Message 10 of 12
Thank you for the reply!
I’ve wondered if there was something like that. I‘ll wait and see what they say.
Skynet_TX
Message 11 of 12
Hi @Genyz,
Sounds like you may be affected by the DNS issues that seems to be affecting a number of customers that have the Sagemcom router. The staff here will be able to help, they may just recommend getting a replacement router sent out to you.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
