Internet connection dropped a couple of nights around same time
blokexx
Message 25 of 25
Mine internet connection dropped out a twice in the last 3 days at 1AM for between 1 to 3 hours. Doesn't seem like a router fault, but more like some service update/upgrade?
The log viewing capabilities on the router is not optimal [cr@p] - you can only go forward/back one page at a time, you can't jump to a page, you can't download it, you can't search it so it took about 300 mouse clicks to get to the page for last outage on 22nd.
You can see in the log output below that there are no messages from 01:04:37 to 04:01:57 which is the length of that service outage (I know this  because my Nest cameras and Access Points alerted me about loss of connectivity to cloud services during this time period). Although the log is set to debug level, it doesn't really give a clue as to where the issue is - did the router go down, did the line go down, only see that it acquires an IP address at the time the service is restored???
BTW: the log is full of a lot of messages "DNS name resolution failure (_bookmarkdavs._tcp.p51-bookmarks.icloud.com)" - what's that about?
22.08.2019 04:02:00 Info SYS TR-069 connectivity to (acs.talktalk.co.uk) has been closed
22.08.2019 04:01:57 Info DHCPC The WAN DHCP client IP address 2.100.207.20
22.08.2019 01:04:37 Error DNS DNS name resolution failure (_bookmarkdavs._tcp.p51-bookmarks.icloud.com)
24 REPLIES 24
Message 1 of 25
Hi @blokexx
We have requested an engineer to go out to the exchange in the next 48 hours.
We can check the fault ticket on Thursday for an update
Message 2 of 25
Thanks for the update, We will do some further checks from here and let you know.
Message 3 of 25
Hi - I noticed that some line test must have been done this morning as the phone showed a line disconnect (?). I tried a couple of incoming/outgoing test calls and whilst it was much better than the other day when the crackling was almost constant, there would still be a loud crackle every now and again which was loud enough to not hear the other party.
Message 4 of 25
Hi blokexx
Apologies for the delay.
Thanks for the Private Message. Just to confirm, is the noise on the line still present at the moment?
Message 5 of 25
Thanks for the PM, I've replied requesting a bit more information
Message 6 of 25
On the top right of the page just underneath your avatar, you should see a blue envelope icon, if you click on this you should see the PM from me. If you open the PM you can reply by clicking on the blue reply button on the bottom right - hope that helps 🙂
Message 7 of 25
Sorry - how do I reply privately just to yourself?
Message 8 of 25
Hi blokexx,
If you'd like us to go ahead with the engineer visit can you provide availability, either AM (8am to 1pm) or PM (1pm to 6pm) between Monday to Friday.
I've also PM'd you to confirm some other details
Message 9 of 25
Yes thats Ok.
Message 10 of 25
Hi @blokexx
All the line tests we run are not indicating any problems, if we book an engineer and they don't find a fault there will be a £65 charge, are you willing to accept this?
Message 11 of 25
The crackling on the line returned couple of weeks ago and exists when I swap the cordless phone base with the corded phone I bought so I will need to have someone come out and take a look.
Message 12 of 25
The line test is intrusive and will disconnect the circuit while the test is ran.
Keep an eye on things and do let us know if the issue returns.
Message 13 of 25
Hi Karl - I saw that there must have been some sort of line test this morning as the phone reported the line was disconnected. Since then the crackling has gone! Would the line test have reset something that may have been causing it?
You can close thsi down for now and if it comes back I will re-report.
Message 14 of 25
Testing with a different handset at the test socket demonstrates the issue is external.
This will need an engineer to resolve.  As the usual line tests are showing clear and not picking up the issue then we will have to make an appointed visit.
I'll send you a PM with the info required.
Message 15 of 25
Hi Debbie - finally got a corded handset, took off the front of the master socket (which has built in filter) and plugged it into the socket inside. The crackling on the line when I made a couple of test calls is still present, so looks like a line issue somewhere.
Message 16 of 25
Hi blokexx
Ok, please let us know how you get on.
If the noise is still present at the test socket then we can pass this fault over to our Network Team for investigation.
Message 17 of 25
The cordless base is all neatly wired in some trunking behind a shelf so would require major extraction ;-( I'll see if I can borrow one or buy a cheap one on ebay.
Message 18 of 25
Hi blokexx
Would it be possible to test your phone on a different line (family or friends line) to see if you still experience any noise? This would help rule out the handset being faulty.
Message 19 of 25
Unfortunately haven't had a corded handset for many years 😞 Might see if I can borrow one, but think everyone has cordless ones nowadays.
Message 20 of 25
Hi blokexx
Noise on the line can affect the BB connection. Is the noise still present if you test with a corded handset at the test socket, with the router removed from the line?
