Internet connection keeps Dropping Out
Dcotto1
Message 18 of 18
Keep geeting the dreaded amber light most evenings recently and it was especially bad too during the day on bank holiday monday which suggests a shortfall in bandwidth in our area. Can you please investigate.
D J COTTOM
17 REPLIES 17
Dcotto1
Message 1 of 18
Internet speed down to 12mb/s again!!!! Really frustrating as problem was 'resolved' in May. Can you please send the BT engineer out again to investigate their apparatus.
D J COTTOM
Dcotto1
Message 2 of 18
So I'm back down to 12mb/s again which is really frustrating after problem was apparently resolved in May!!!! Can you please arrange for a BT engineer to check their apparatus again. I'll be going back to VM at this rate.Screenshot 2021-07-06 123615.jpg
D J COTTOM
Message 3 of 18
That's great news, thanks for letting me know.
Message 4 of 18
BT Engineer has now resolved. Thanks
D J COTTOM
Message 5 of 18
Fault is still with Openreach.  Engineer has found a low AC balance on the D-side, that's between you and the main cabinet.   Engineer was unable to resolve and has escalated this internally within Openreach for an Underground skilled engineer.
Message 6 of 18
My contract is says I should be getting 67mbps download speed so only operating at 20%?
D J COTTOM
Message 7 of 18
I've had a poor internet connection all day - just did a speed check and got these results?
D J COTTOM
Message 8 of 18
Give us a nudge on Monday and we'll check the Openreach notes for you.
Message 9 of 18
OK thank you. I look forward to the update.
D J COTTOM
Message 10 of 18
Hi Dcotto1
I've escalated this fault over to Openreach to be investigated by a line engineer and we should receive further updates from Openreach within the next 48-72hrs.
Message 11 of 18
Hi @geoffeales,
You will need to start your own topic on the community for the staff here to be able to help, as they can only help one customer per topic. What make / model of router do you have, if it is the Sagemcom Wi-Fi Hub then the symptoms you describe do sound like a common issue that can affect that model of router.
geoffeales
Message 12 of 18
can anyone help me? I am convinced there's a fault with my router. On average I have no connection about twice a week for the last 3 months or so. When I unplug and reconnect the router it fixes every time. Service check says there's no fault on the router or the line - but that of course can only be checked when I'm up and running on-line. When it's down there's no way of checking, the white light is continuous which would suggest it's OK but the only way to fix is to reboot. My 18 months is up 2nd June and at this rate I'm tempted to look for another provider, but would rather sort this as when it's up and running it's great. Help!
Message 13 of 18
It just dropped out again!
D J COTTOM
Message 14 of 18
Yes it is
D J COTTOM
Message 15 of 18
Hi Dcotto1
I've completed a line test which has detected a possible fault.
Is the router still connected at the master socket at the moment?
Message 16 of 18
No connection test issues.
Phone line working normally.
Do not have a test socket.
Porfile updated.
Problem is intermitent not permanent.
D J COTTOM
Skynet_TX
Message 17 of 18
Hi @Dcotto1,
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
