Internet down
EEBEE
Message 22 of 22
Internet has been off for most of the day.  Flashing orange n white light.  Turned hub off for a duration.  Have now got solid orange light.  Please help!
Also, internet light is off on openreach box.
21 REPLIES 21
Message 1 of 22
@EEBEE wrote:
My neighbour has the same problem with BT, they have given her some freebies as compensation... I'm just saying 😉
Your neighbour is probably paying a lot more for her broadband than you are. BT are a premium supplier, TalkTalk are a budget supplier.
Message 2 of 22
I've not noticed any further disruption with the connection so assume fixed, unless your line test shows anything.
Many thanks,
Ian
Message 3 of 22
Keep monitoring and do let us know if anything changes.
Message 4 of 22
As far as I'm aware the connection has been up for 17+ hours.  So looking good (*@#][!![]'#[@#]!* I've said it now :)).
There's still a hole in the pavement, and nobodies been near all day, so I'm not counting my chickens just yet.  Albeit I haven't confirmed the dig is related.
Cheers,
Ian
Message 5 of 22
Hi Ian
Thanks for the additional information.
If dig work is required then it may be a bit longer before the fault is fully resolved but I am glad to hear that the engineers are there working to resolve this fault.
Message 6 of 22
Daily update....
... The openreach guys still got the box open and now there a hole in the pavement.   The connection is like a yo-yo, but to be fair, a slow one.  I gather they're still working on it, and the good thing is they are working on it.   My neighbour has the same problem with BT, they have given her some freebies as compensation... I'm just saying 😉
Ian
Message 7 of 22
Hi Ian
The same issue is still being detected (Openreach issue) Hopefully the engineers can fully resolve this fault as quickly as possible.
Message 8 of 22
An openreach guy has his head in the exchange box at the end of the street when I got home from work at 5:30pm.  The connection appears to have been ok until 9pm ISH. So I assume they're still working on it.  I have just powered off again in an attempt to recover...
Something to note, in the hub logs there are lots of errors for 'The WAN DHCP client process has failed on vlan 36'.  Am I correct in thinking this is a business address?
Cheers,
Ian
Message 9 of 22
An openreach guy has his head in the exchange box at the end of the street when I got home from work at 5:30pm.  The connection appears to have been ok until 9pm ISH. So I assume they're still working on it.  I have just powered of again in an attempt to recover...
Cheers,
Ian
Message 10 of 22
I'll check again later on today to see if there are any updates on this fault/outage and will post back here.
Message 11 of 22
I'll assume a fix is in progress then?
Cheers,
Ian
Message 12 of 22
HI
This is still showing when we test.
Message 13 of 22
Thanks for the info.   Has the existing network event been fixed or is there to be further outage?
Cheers,
Ian
Message 14 of 22
I'm now showing that your line is affected by an existing network event - this means an outage on the openreach side.
Message 15 of 22
Sorry I thought I replied earlier...
Good to hear of possible issue
No, the voice service is not affected.
Thanks,
Ian
Message 16 of 22
I'm sorry to hear this. The line test is now detecting a possible issue. Can I just confirm, is the voice service also affected? Do you have a dial tone?
EEBEE
Message 17 of 22
Hi Debbie,
Thanks for getting in touch, sorry for delay in reply (I'm in the office :()
Yeah, it disconnected again late last night, so I left it powered on overnight and it was reset this morning.  Same symptoms as before.  I am told it has gone off again this morning but I cannot give specifics.
Thanks,
Ian
Message 18 of 22
Hi EEBEE
I've completed a line test which hasn't detected any faults and the sync speed looks good.
Are you still experiencing this fault?
EEBEE
Message 19 of 22
The latest...
Saturday 21:15, no internet again, solid orange light.  Powered off/on numerous times to no avail then left switched on overnight.
Sunday Am, internet connected.
Sunday 13:30, came home to find internet not connected again.  Solid Orange light and no DSL or internet lights on openreach modem.  Powered off for 30 mins.  14:06 connection restored.
Sunday 17:30, connection lost.  Solid white light on Hub but no DSL or Internet light on Modem.  Hub lights progressed thru white/orange flashing to solid orange.  I left it alone for an hour to see if it recovered with no intervention, it didn't.  Powered off at 18:40, connection restore at 19:06.
A line test showed no issues.  Nothing has been change in my setup/hardware, so need to find out what is failing.  As the DSL light is not lit on the modem then my thoughts are the issue is before is either with the modem or before this.    Please can this issue be progressed or do I have to contact support?  Please advise.  Thanks in advance.
Until the beginning of this month I was working from home for 2 years, and I'm happy to say with no connection issues.  Working in IT development I need a constant/reliable connection and have always praised talktalk reliability.  But, when it has gone wrong in the past it was a pain the posterior, hope this time doesn't prove to be the same.   I will be returning to working at home shortly, so I need this working.
EEBEE
Message 20 of 22
Thanks for the pointers...
I went through the diagnostic routine, and powered both boxes (Hub and modem) plus the reset buttons numerous times last night to no avail.  I left both boxes switched off overnight.  This morning I powered back on, only to get the solid orange light.   On attempting to login to the hub via my laptop (wireless) I went to the hub to get the password to find the light had gone WHITE.  Now I'm not sure if it recovered itself or attaching to the hub (logon screen only) did the trick.  Whatever it was, it's back on now.
I'm told the connection was off/on a couple of times yesterday, so time will tell...
