on 01-03-2021 06:02 PM
Internet keeps dropping randomly. Have the Huawei-DG8041W router. Tried splitting networks to 5g and 2.4g, it worked for a while but now the internet keeps dropping again constantly. Also the light on the router isn't working, even when the internet seems to be connected. The orange lights work on reset fine, but the blue light that used to come on to say it was connected is just blank. Any help here would be great. Thank you! P.S not possible to connect anything to ethernet, everything in the house is wireless.
on 23-03-2021 12:33 PM
Hi MarkInglis
I'm sorry for the delay.
I have now switched off the WIFI optimisation. @KeithFrench.
on 21-03-2021 10:06 PM
Hi @MarkInglis
Before I can help you, as I said in my post #19, you first need to request WiFi Optimisation be disabled. Please re-read the last paragraph for details.
on 21-03-2021 04:41 PM
If you can help that would be great. Not sure why the 2.4G has just decided not to work at all. 5G works fine for the most part, downstairs, but because upstairs at the back of the house is far from the router, it drops loads.
on 21-03-2021 03:43 PM
So do you want my help or not as per my last post?
on 21-03-2021 03:41 PM
The issue with this is... The 5G will not reach upstairs and the 2.4G for some reason doesn't work at all now. Not even after resetting the router. If the router was in the middle of the house I think it would fix the whole issue. When we had Sky broadband it was in the middle of the house and we rarely had issues with it. If the engineer had put the extension into the middle of the house when we first had fibre installed I'm pretty sure things would have been working fine.
on 16-03-2021 10:36 AM
Hi @MarkInglis
@Michelle-TalkTalk has asked me to help you. First off the LED can be turned off in the configuration of the router, which will stay off except when rebooted, but will go out again when the internet is up.
There is another approach, rather than splitting the SSID names, which can be better, which is to use Band Steering. This will automatically move any 5G compatible device connected to the 2.4G band to the 5GHz band. To use this facility on the Wi-Fi Hub, leave both network names identical. However, neither approach will actually fix the problem.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
There is one further complication with the Sagemcom hub, which needs addressing before I can help you further. A TalkTalk remote diagnostic utility called "WiFi Optimisation" needs to be turned off, otherwise, this can override any changes I might recommend be made to the router. Please can you request that TalkTalk disable this feature on your Sagemcom (assuming that you are using this router currently) in your reply?
Once done, if you want my further help, please let me know.
on 16-03-2021 08:32 AM
Hi Mark,
I've re-checked the connection stats now and the sync speed looks really consistent and the connection also looks stable. @KeithFrench - Would you be able to offer any additional advice in regards to the wireless connection?
on 14-03-2021 01:57 PM
Hi Debbie. Thanks for the reply. Nothing can be connected to wired. The router isn't in the most convenient place so everything needs to be on wifi.
on 13-03-2021 03:45 PM
Hi Mark
I'm so sorry to hear this.
Can I just check, do you have any devices connected wired? Are they experiencing the same issue?
on 11-03-2021 08:23 PM
New router setup. Split the SSID. First night disconnected. Last night disconnected. Now the 2.4ghz won't stay connected and the connection is very unstable for my xbox and PC upstairs. Can't move it closer. I have a signal booster for the 2.4g which says it has 100% signal strength but the internet still keeps disconnecting repeatedly.
The 5g won't stay connected upstairs either it's only 50% strength. The engineer that initially installed our first router said we wouldn't need it to be in the middle of the house because it would reach everywhere and be a strong signal. We haven't had a strong signal since day one.
SO I had to buy a signal booster, which helped a bit, but now the internet disconnects all the time. Today it's been really awful. The lights are all working on the new router though. I need this fixed, some of my work from home needs to be done on the internet and I can't do it because of constant disconnects.
Even trying to send this post through, disconnected 3 times.... 4 times now.
on 08-03-2021 06:52 AM
Hi Mark
Thank you 🙂
on 05-03-2021 08:31 PM
Great, thank you. Hope it fixes the issues. Will let you know how it goes when it arrives.
on 05-03-2021 07:54 PM
on 05-03-2021 06:15 PM
Is the new router free? I hope there is no hidden costs for this. The internet today has been atrocious, can't stay connected for more than 15 minutes without being thrown out then reconnecting again. It's happening repeatedly today.
on 05-03-2021 02:59 PM
Okay, thank you, will let you know how it gets on.
on 05-03-2021 06:48 AM
Hi Mark
I've ordered you the Sagemcom WIFI hub for testing, please allow 24-48hrs for this to arrive.
on 04-03-2021 03:05 PM
Thanks for the reply. Nope, no alternative router available here. If you send another, would it be able to be a different model? Been seeing a lot of negative feedback for the huawei-dg8041w.
on 04-03-2021 01:05 PM
Hi Mark,
Do you have an alternative router that you can test with to rule this out? If not then we can send a replacement router for testing purposes.
on 03-03-2021 02:39 PM
Just another quick update. The internet disconnected again. The light on the router still isn't working.
on 03-03-2021 02:09 PM
Thank you for the reply. Yes it has a test socket. The phone has a dial tone, working fine. I reset maybe 3 times. The internet seems a bit more stable yesterday, but still no light on the router. I think it might be knackered. Been seeing a lot of bad things about the router we have. QoS issues, which seems to be the case here too.
