Internet intermittent
awforbes
Message 3 of 3
I was told by Talktalk that if I upgraded to fibre my internet would be much faster and there would be no drop out problems. Well, nearly a year later and many complaints, my internet keeps dropping out. I have read similar complaints and see that nothing has been done about this. Talktalk cannot or will not address this issue.
There many unstisfied customers out there with exactly the same problem, and I believe there is no other option!
I think I will have to just give up and get another service provider.
Message 1 of 3
Hi awforbes
  • Name
  • Telephone number
  • Alternative contact number
Divsec
Message 2 of 3
Hi AW, welcome to the community, your post has been flagged for assistance and you should hear shortly. Please check your community profile and add your landline phone number if necessary it is used to identify your account.
I wouldn't give up hope yet, the team here are very good and dedicated to finding a solution.
You can help them to help you with a bit more information.
What speeds were you promised and what are you seeing
Which router do you have
How often does the connection drop
Have you the same issue connected WiFi and cable
Have you tried resetting the router
Good luck and please don't forget the team here work office hours.
D
