Internet keep disconnecting after upgrade
Choong
Message 32 of 32
After upgrading my fibre to fibre 65. The 2.4ghz channel keeps disconnecting and 30 mins later it will drop internet.
I have done a soft and hard reset but still the problem continues. I have left the router off for 2-3 hours and still no joy.
any suggestions I can try as it is becoming a nightmare.
31 REPLIES 31
Message 21 of 32
Hi Ferguson,
Attached as requested
Message 22 of 32
Could you post a picture of your master socket? Use the camera/Insert photos icon
Message 23 of 32
Hi Michelle,
I have the master socket with two sockets (FTTC) and when I took the screws out . The socket wanted to come off the wall so I stopped.
thanks
Tony
Message 24 of 32
Hi Choong,
I'm sorry to hear this and I will take a look now. I've run a test on the line which is clear, however I can see re-connections on the line. Does your main socket have a test socket?
Message 25 of 32
Hi Karl,
I hope you had a great weekend!.
unfortunately the issue is still there 😞
I have posted the old router back to talk talk today
any other suggestions i can try?
Tony
Message 26 of 32
No problem, See how it goes over the weekend.
Message 27 of 32
Hi Karl,
received the router - thank you
will reply back soon about the issues
Message 28 of 32
No Problem 🙂
Message 29 of 32
Thank you Karl 🙂
Message 30 of 32
Hi Choong
I'm not seeing any line issues and the overall sync speed looks fine.
I've a new router on the way to you so we can rule out a hardware issue.
Sarah75
Message 31 of 32
I’m experiencing the same problem. Come evening I can’t watch any tv in my bedroom
