Internet keeps crashing
KerryB78
Message 40 of 40
Hi, been having problems with internet coming and going. I have 3 children all gaming at the same time. I've run a speed check and its reading 24 mbps, I have spoken to a friend who works in IT and he said for the amount of usage we need at least 100mbps. Is there anyway to boost connectivity?
39 REPLIES 39
martswain
Message 1 of 40
@KerryB78  if there is a line or cabinet fault that is limiting your speed, even if that is fixed the best you can expect from any ISP that provides service over the phone line is the high end of the TT estimate, 28.
The length of your phone line is the limiting factor on a FTTC service.
To get the speeds you say you need you would have to move to a full fibre service or Virgin Media.
Ask for the Loyalty Team on 0345 172 0046 or 0345 172 5157
Message 2 of 40
Ok thank you. Do you have the loyalty teams number please as I can't seem to find it?
Message 3 of 40
Hi KerryB78
Apologies for this.
If you contact our Loyalty Team by phone or Live Chat then they can discuss this further.
Message 4 of 40
Ok thank you. Unfortunately that's not fast enough for what we need. Can you tell me if there is a fee for leaving my contract early and if so, how much please?
Message 5 of 40
Hi KerryB78
Thanks for confirming your details.
The predicted speed range for your line is showing between 26.8 and 24.1mb, and with a guaranteed minimum speed of 21.7mb.
Message 6 of 40
Hi KerryB78
I'm just sending you a Private Message to confirm some details so we can check the predicted speed range for your line.
Message 7 of 40
Ok Debbie, thank you. What is the maximum speed I could get when everthing is working properly? We need at least 50mbps, do you think that will be possible? If not I may need to move to another provider.
Message 8 of 40
Hi KerryB78
I've checked and I can see that your router has the latest firmware version.
Message 9 of 40
Where would I find that?
Message 10 of 40
Can you also see the version of firmware?
Message 11 of 40
  • Sagemcom- FAST5364
Message 12 of 40
Apologies, I can't currently connect to the router. Which version of firmware is currently showing?
Message 13 of 40
No problem,  thank you.  I've just noticed on my account it says my software needs updating, could this be part of the problem?
Message 14 of 40
Thank you. Would it be possible to keep the router connected at the test socket whilst we are looking into this and I will re-check the connection stats in the morning to see how the stability compares and also if DLM has made any changes to the speed?
Message 15 of 40
I have plugged the router into the test socket now
Message 16 of 40
I'm sorry for the delay. I've re-run the line test now which hasn't detected a fault, however the connection looks very unstable which will affect the broadband speed. Is the router now also connected directly at the test socket?
Message 17 of 40
DS - 20
US- 3.7
Minimum guaranteed is 21
martswain
Message 18 of 40
@KerryB78  what is the actual sync speed as reported in the router interface when you log in at 192.168.1.1 ?
You need to look at the DSL page and Downstream/ Upstream Line Rate
How does that compare with your minimum guaranteed speed as advised in Service Centre ?
Message 19 of 40
Ok, thank you 😊
Gliwmaeden2
Message 20 of 40
Staff will follow up on Monday, @KerryB78 - they are not on here at weekends.
