Internet keeps dropping
greenturnips
Message 32 of 32
Ive been having trouble over the last few weeks, where the internet drops for about 30 seconds and then reconnects.  The WiFi is still showing as connected but the internet is non existent.  This is happening about 6 or more times a day.
Any ideas, I normally wouldn’t be bothered, but this is effecting the gaming side of the internet.
31 REPLIES 31
Message 21 of 32
Message 22 of 32
Yes will do
Message 23 of 32
Hi greenturnips
Please let us know how you get on once you have received and tested with the replacement router.
Message 24 of 32
Message 25 of 32
Hi greenturnips
This will be the HG633 router, this is one of our Super Routers.
Message 26 of 32
Which router is it, is it the WiFi hub?
Message 27 of 32
Hi greenturnips
The replacement router is on its way, there will be no charge for this.
Please allow 24-48hrs for this to arrive.
Message 28 of 32
Yes, I have a white BT white box which goes to the socket, then a separate WiFi router connected to that.
It would be a good idea to try a replacement, would this be at any cost?
Message 29 of 32
Hi greenturnips,
Just to confirm, are you currently using a BTOR modem and separate router? Would you like us to send a replacement router for testing purposes to rule this out? This would replace both the current router and BTOR modem.
Message 30 of 32
The line appears to be noise free, I can’t vouch for when it disconnects though, may need to test this when it happens. I don’t think the master socket has a test socket.
could it be the router or bt fibre (white) box?
Message 31 of 32
Hi greenturnips,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault, however I can see re-connections on the line. Is the voice service ok? Are you experiencing any noise on the line?
Does your master socket also have a test socket?
