Internet not working again
sharky110
Whizz Kid
Message 1 of 129
My internet is playing up again keep losing connection whilst on my xbox also while using BBC I player also losing connection  on my phone I am fed up with this now been happening  a lot recently can somebody  help please
Kieran
128 REPLIES 128
Message 2 of 129
Hi sharky110,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault and the connection looks stable for 5 days. Do you have any devices connected wired to confirm if this is only affecting wireless? We can then offer further advice on the wireless connection.
Message 3 of 129
@Michelle-TalkTalk its wired and wireless  I have connected my laptop with  wired and is still slow it's not opening web pages properly  it's taking a long time to connect to the internet  it is the same as it was last time your end is not showing a problem why does it keep  going like this  my firebox was buffering on bbc I player also kept stopping why can I not get an internet  connection that stays working
Kieran
Message 4 of 129
Hi sharky110,
Thanks for confirming this. The sync speed also looks good so this shouldn't cause any issues with performance. Could you try rebooting the router and then letting me know if the buffering is still happening following this please? Is the voice service also ok?
Message 5 of 129
@Michelle-TalkTalk I will reboot now what do you mean voice service
Kieran
Message 6 of 129
Hi sharky110
Thank you. The voice service - when you make calls from your landline.
Message 7 of 129
@Michelle-TalkTalk  landline seems to be  ok
Kieran
Message 8 of 129
Hi sharky110
How has the connection been since you rebooted the router?
Message 9 of 129
@Debbie-TalkTalk still seems the same at the moment
Kieran
Message 10 of 129
Hi sharky110
Apologies for this.
Does the buffering still occur if you connect just one device (wired) with no other devices in use?
Message 11 of 129
Yes it is with only one device  connected two phones connected that's about it
Kieran
Message 12 of 129
@Debbie-TalkTalk previous message
Kieran
Message 13 of 129
Hi sharky110
Your line is showing in sync at 40mb.
I've updated your router firmware version. Please can you test this again and let us know how the connection compares.
Message 14 of 129
@Debbie-TalkTalk thanks I will
Kieran
Message 15 of 129
Hi sharky110
Thank you, please let us know how you get on.
Message 16 of 129
@Debbie-TalkTalk hi just turned my firestick on and its saying no internet  connection
Kieran
Message 17 of 129
@Debbie-TalkTalk  just checking setting on firestick says connected to wifi no internet connection
Kieran
Message 18 of 129
Hi sharky110,
Sorry to hear this. Do you have an alternative router that you could test with to see how the connection compares?
Message 19 of 129
@Michelle-TalkTalk I might be able to find old one not sure but dont think that will run my fibre they changed the router when I got fibre
Kieran
Message 20 of 129
Hi sharky110,
Ok, would you like us to send a replacement router for testing purposes to rule this out?
