Internet speed ridiculously slow
Shousty
Message 8 of 8
Ever since this morning my internet speed has slowed down to a crawl, I'm barely getting dialup levels of speeds at best, tried turning off router for 30 mins but nothing  helps.
7 REPLIES 7
Message 1 of 8
Hi Shousty
Would you like me to send a replacement router for testing?
Shousty
Message 2 of 8
No I didn't have another router to spare, my main device is my laptop, and I connect wirelessly on mobile on occasion, I left things for a few hours, things seem okay now. I'll let you know if anything changes.
Message 3 of 8
Ok, do you have an alternative router that you can test with? Is the speed slow on more than one device?
Shousty
Message 4 of 8
Happens regardless wired or not, Laptop wired, wireless everything else.
Message 5 of 8
Hi Shousty,
Thanks for confirming. I've re-checked the connection stats now and the sync speed looks good. Can I just confirm, are you connected wired or wireless at the moment when experiencing the slow speeds?
Shousty
Message 6 of 8
Just turned it back on, internet was fine earlier but speeds were slowing down since early this morning, now I can barely connect without issues.
Message 7 of 8
Hi Shousty,
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault. Is the router currently switched off?
