Ipaddress reservation
hallergard1
Message 8 of 8
My SKY contract is soon up and I am considering migrating to Fiber 65.  Believe it comes with Huewei DG8041W hub?  Read a review stating that it could not reserve ipaddresses.  Has there been a firmware update adding this capability?  What about the Sagemcom hub?
7 REPLIES 7
Message 1 of 8
f all you want to do is apply DHCP IP address reservation, why not stick with what you have? It works well. Assuming that you have the DG8041W login to it & go to:-
Dashboard > See Internet Settings > Manage advanced settings > Advanced Configuration > LAN Configuration > DHCP Static IP Configuration
This displays the current list of static IP addresses. To add new one, click the Add button & enter the MAC address to be reserved.
hallergard1
Message 2 of 8
Thanks, understood.  Any suggestion?
AllyM
Message 3 of 8
Also, you can use your own third party router if you prefer, so I don't think you should let the model of router that an ISP supplies affect your choice of provider.
hallergard1
Message 4 of 8
Thank you!
Message 5 of 8
So can the Sagemcom, but not the initial firmware. V2816 or later is fine.
hallergard1
Message 6 of 8
Thank you  very much for the info!
Piethorne
Whizz Kid
Message 7 of 8
The Huawei DG8041W can reserve IP addresses - the review you read is incorrect.
I'm just a customer who might be able to help, not official help & support.
