Issues with connection via work VPN last 6 months
Launchyourself
Message 20 of 20
Hi For the past 6 months my work PC has started to have intermittent connection during the day through my work VPN and Talk Talk Router. My work IT team has mentioned that the Cisco Anyconnect VPN is not compatible with Talk Talk. I've switched off all the Homesafe settings but this has not helped. The PC Laptop works via VPN through none Talk Talk routers & there is no issues with other devises using the internet in my household. I think its the compatibility with the Sagemcom router. I had a similar issue over 2 years ago that was resolved by Talk Talk sending me a new Router. Can someone offer any advise or help?
19 REPLIES 19
Message 1 of 20
How are you getting on? Is everything now ok?
Message 2 of 20
No Problem.
Launchyourself
Message 3 of 20
Thanks Karl
Message 4 of 20
would not hurt to try. I'll get one out to you.
Launchyourself
Message 5 of 20
I'm wireless, there it's still ongoing connection dropping out on my work laptop though the vpn. The other house hold devices are fine. Maybe I need a new router?
Message 6 of 20
I've checked again and I can see that your router does have the correct FW version for the issue with VPN.
Do you connect wired? Does the issue happen wired and wireless?
Launchyourself
Message 7 of 20
It's job the connection via the vpn to my laptop. All over devices work fine with no drop in connection.
Message 8 of 20
Is it just the VPN connection dropping now or the connection as a whole?
Launchyourself
Message 9 of 20
Just monitored past two days, it still periodically disconnects/ reconnects a few times during the working day. I feel that the connection could be more stable as it was throughout 2021.
Message 10 of 20
How are you getting on? Is the VPN connection now working ok?
Thanks 🙂
Message 11 of 20
OK, I've started the upgrade process, it should complete within 20 minutes, please don't switch your router off
Launchyourself
Message 12 of 20
Yes that's fine, please proceed
Message 13 of 20
No problem, is it OK to update it now, it can take up to 20 minutes for the update to complete?
Launchyourself
Message 14 of 20
Yes can we try a different firmware version, thanks.
Message 15 of 20
OK thanks. We can try a different firmware version, would you like to give this a try?
Launchyourself
Message 16 of 20
No I just get a message on my pc everytime it "reconnects" only.
Message 17 of 20
OK thanks. Do you get an error message when the VPN disconnects?
Launchyourself
Message 18 of 20
It only works on someone else's line. My line is currently intermittent via my work VPN.
Chris-TalkTalk
Message 19 of 20
Hi Launchyouself,
Just to confirm, when you say that the VPN works through non-TalkTalk routers, is this non-TalkTalk routers connected to your line or to someone else's?
