Issues with d-link router
davidjl1985
Message 4 of 4
I've recently moved to a new house and decided to upgrade from 'Super Fast' broadband to Fibre 65. I'm still using my old router (d-link dsl-3782) and the signal is terrible. If I move more than 3 metres away from the router the signal drops from 4 bars (which is the max) to 1 bar. I've used a WiFi Analyser to see if there's any interference and this doesn't seem to be the issue. Other networks that are close by are using different channels with no overlap. However, the Wifi analyser says that I'm 50m away, when I'm actually only 6-10m away. I seem to get a better signal from my neighbours’ routers (that are over the road) than my router which is in the next room.
Anyway, I noticed that the WiFi Hub Black comes as standard with Fibre 65. Should I request an upgrade? Does anyone know if the WiFi Hub Black offers improved coverage?
thanks in advance!
3 REPLIES 3
Message 1 of 4
Hi davidjl1985
Please let us know how the connection compares with this router.
davidjl1985
Message 2 of 4
That would be great. Thanks Karl!
Message 3 of 4
I'll get a new router out to you and see if this helps with the wifi issues.
