Issues with fibre 65
Phil72
Message 12 of 12
So on the day of installation the engineer ran a test and told me I was getting 40 Mbps to the router and to this day I've not seen my service reach that speed.
What we have achieved is lag, drop outs, buffering including pages not loading.
Sign into my account and it flags up latency issues with my samsung S20 + and now the latest one is showing issues with my speed which by the way keeps reducing everytime I disconnect the router for half an hour to restart a new session at the cabinet.
Not impressed with Talktalk fibre 65
11 REPLIES 11
Message 1 of 12
Hi Phil72
Phil72
Message 2 of 12
Yes if you would send me out a router to test that would be helpful.  Thank you
Message 3 of 12
Hi Phil,
Ok, would you like us to send a replacement router for testing purposes? We would also send a router returns bag so that one of the routers can be returned.
Phil72
Message 4 of 12
Good Morning
No I haven't tried different router, just the original one sent out to me.
Message 5 of 12
Hi Phil,
Thanks for confirming. Have you ever tested with a different router?
Phil72
Message 6 of 12
The router is already connected to the test socket and the predicted speed is 36.8 which I was getting and has now dropped to 34.4
Message 7 of 12
Hi Phil,
I've run a test on the line which hasn't detected a fault. Does the main socket have a test socket? Were you provided with a predicted speed range for the line?
Message 8 of 12
They aim to respond within 48 hours (Monday - Friday), but if more urgent you can always try the Service Centre. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
Phil72
Message 9 of 12
So after unplugging the router for 30mins the I'm only getting 34 mbps at the router was at 36 originally with issues.
A speed test comes back at 32 on a wireless & wired connection.
Message 10 of 12
Have you turned the router off for at least 30 minutes. Then tell me what the sync speed as measured by your router after that. From there I can probably help you.
Skynet_TX
Message 11 of 12
Hi @Phil72,
If you go to the Service Centre what does it show for your estimated speed range. If you log into your router to check your sync speed does this show speeds below that estimated range. If you run a speed test (ideally from both a wired and wireless device so that you can compare), how close are the speed test results to the sync speed shown on your router.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
