11-05-2022 10:31 AM - edited 11-05-2022 10:43 AM
It's been cranky for a couple of days. I have reset, rebooted, factory reset. None of which helped. It worked early yesterday morning and died about 0915. Came back in the evening and dropped again this morning around the same time. So frustrated as I'm trying to work on a wired connection.
on 30-05-2022 08:43 AM
Ok. If the connection is still dropping when connected wired with 2 different routers, cables and microfilters connected at the main socket with all other equipment removed from the line then the next step would be to arrange an engineer visit to the property.
on 30-05-2022 08:39 AM
Yes but nothing happened. The router light stayed flashing red - it didn't connect. I am using both the new router and the new cable to the socket.
on 30-05-2022 08:37 AM
Ok. When you say that you've tried at the main socket, did you mean that you connected the router to the test socket behind the faceplate?
on 30-05-2022 08:33 AM
Definitely - when it's good it's very good (the cabinet is at the edge of my property) - but it's just been cycling up and down. I've pulled my work down on to my hard drive but I need to be able to send it back (creative services - large files).
on 30-05-2022 08:28 AM
Thanks for confirming. I've re-run the line test which is clear and I can see 1 re-connection in the last 3 days. Would you say that the connection has been more unstable than this?
on 30-05-2022 08:20 AM
This is the replacement router that you sent last week or the week before. I don't know what you can see but yesterday (Sunday) morning the connection was more down than up and it seemed a bit better later in the day, there is no pattern as I've been checking. At the time of writing it is up but I don't expect it will last.
on 30-05-2022 06:53 AM
Thanks for trying this and I'm sorry to hear that this didn't work. Do you have an alternative router that you can test with please?
on 28-05-2022 09:42 AM
@Muntiacus, staff don't usually work weekends on here. Support likely back on Monday.
on 28-05-2022 08:39 AM
Tried the master socket. Precisely nothing happened. The router light continued flashing red/amber so I've put it back. What next? It's enormously frustrating when I have work backing up. I've managed to download it to do but who knows when I'll be able to return it. I have no confidence in the connection.
on 28-05-2022 07:44 AM
Yes there is, I'll try it shortly. I don't want to leave it there for too long as it plays havoc with my alarm system. I will update when I've tried it.
on 27-05-2022 06:47 AM
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault, however I can see a few re-connections on the line. Does your main socket have a test socket please?
on 26-05-2022 04:35 PM
New router and cable. Slightly different problem. Just keep losing connection it keeps timing out. Been happening all day. Paid for broadband in advance, now having to buy mobile data to even communicate here. I am very unhappy.
on 11-05-2022 02:00 PM
Hi Muntiacus
Thanks for the Private Message. The router is on its way, please allow 24-48hrs for this to arrive.
on 11-05-2022 01:43 PM
Hi Muntiacus
Apologies, I've made a change. Please can you try and send the message again?
on 11-05-2022 01:39 PM
It won't let me, I might be doing it wrong. Clicked on your avatar, then send message, then ... nothing
on 11-05-2022 01:28 PM
Hi Muntiacus
Please can you send me a Private Message to confirm the name on the account, I can then send the router for testing.
on 11-05-2022 01:21 PM
If you think it would help - I'll try anything. I can't work like this, it is most frustrating for me and my clients. Thank you.
Is there anything else I can do in the meantime? It seems odd that it collapsed at the same time both yesterday and today. It will be interesting to see if it resolves later today and fails again tomorrow. I don't have the feeling that it's anything inside this house.
on 11-05-2022 01:16 PM
Hi Muntiacus
Would you like me to send a replacement router for testing to see how the connection/speed compares?
on 11-05-2022 01:14 PM
That was the wired test. I've done it again and switched off the wifi so definitely just ethernet.
on 11-05-2022 01:02 PM
Hi Muntiacus
What speed do you receive if you run a wired speed test?
