on 03-09-2020 04:52 PM
Hi there is there any way to check if I have the latest firmware on my TalkTalk Router?
Many thanks
on 04-09-2020 08:51 AM
Hi Raskalarts
I can check this for you.
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 03-09-2020 10:13 PM
Hi @Raskalarts ,
For one of the TalkTalk staff on this forum to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
As @FritzCT says, the firmware will usually auto update overnight if an update is required, but once you have filled in your community profile, the staff will be able to check your router and push out a firmware update manually if it needs one.
on 03-09-2020 07:23 PM
Some will know (not me as I use a 3rd party router) what the latest firmware is but they'll need to know what router you have.
Also the OCEs can push the latest firmware but if you just leave it connected it will auto-update to the latest firmware anyway.
Fritz
