on 20-12-2021 01:57 PM
I am on the Faster Fibre - or whatever its equivalent is - and my Internet connection speed is never faster than 16 Mbsp.
I have carried out all the checks on the TalkTalk troubleshooting page.
The connection frequently drops out, or goes under 1 Mbsp - usually once a day. I have a new router - delivered last week - and this has failed to fix the problem.
These kind of speeds have been delivered for at least a year, possibly five years. It's only now I have enough time to address the problem.
I understand that my expected speed should be around 135 Mbsp - Can somebody please explain why my speeds are so far below this, and what must be done to fix it?
Matt
on 23-12-2021 11:08 AM
Glad to hear the speed has improved, just let us know if you experience any further problems 🙂
on 23-12-2021 10:25 AM
Thanks Chris - the download speed is now 36.5 mbsp.
I think this case can be closed. Thank you for your help.
Matt
on 23-12-2021 09:16 AM
OK thanks. Your sync speed is showing at 40Mbps so could you switch your router off and leave it off for at least 30 minutes then switch back on and retest, please let us know how you get on
on 23-12-2021 09:05 AM
Hi Chris
I'm afraid my download speed is 6 mbsp - which is a fraction of the speed I expect for my package.
Are there any further checks to take with my line?
Matt
on 23-12-2021 08:25 AM
Hi mattjreid,
The fault has now been cleared and closed, is everything OK now?
on 21-12-2021 08:14 AM
Hi Matt
Sorry for the delay.
The fault has been raised to Openreach to be investigated by a line engineer.
We should receive further updates from Openreach within the next 48-72hrs.
on 20-12-2021 07:32 PM
Yes the staff can see when you have replied, they only work UK office hours, so will hopefully get back to you tomorrow.
on 20-12-2021 05:24 PM
Did you receive a notification for my reply? see earlier.
I'm not sure if you get notified when I reply to my own post.
on 20-12-2021 02:47 PM
Hi Debbie
I'm afraid I don't have a phone connected to the landline - or indeed any phone that I could use to test the connection.
What would you suggest I do instead?
Matt
on 20-12-2021 02:10 PM
Hi Matt
I've completed a line test which has detected a potential fault with the landline service and this can affect the BB connection.
Are you experiencing any noise on the line when making calls?
