Line fault - fibre
SunHounD
Whizz Kid
Message 30 of 30
Hi there.
It appears I've developed a line fault. At about 2.30pm today, I had a series of disconnects. Upon the connection finally stabilising, my downstream is down to less than half of what it was.
This is what I'm currently getting
  luckily, my router has a built in speed test, so I can provide a pic of previous results vs now, with the latest topmost.
  I have also no dial tone on my landline.
Everything is connected directly to the test socket by a new micro filter (just changed it to rule out that being the problem). There are no extension cables, the filter is plugged directly in to the test socket. (the faceplate hasn't worked in a long time).
I do currently use my own 3rd party router, which is new. To rule out the router being the problem (which wouldn't affect the dial tone of the phone) I've also tried it with the talk talk supplied router (Hg633) and the problem remains the same.
I've contacted live chat which were hopeless (which I knew before I did it, #facepalm) and they told me after a long time, that they couldn't test my line, and to try again later... Nope!
Your help would be much appreciated,
Kind regards,
Nichola
PS.. Personal details updated
Proof, or it didn't happen! ||| Yes, I've tried turning it off and on again!
29 REPLIES 29
Message 21 of 30
Hi Nichola
Thank you. Please let us know how you get on following this visit.
Message 22 of 30
Hi Debbie,
That's fine, thank you.
Kind regards,
Nichola
Message 23 of 30
Hi Nichola
Openreach have arranged an engineer visit for 06/05 AM (8am - 1pm)
Will this date and time be ok?
Message 24 of 30
Hi Nichola
Thanks for confirming this.
I have escalated this fault back over to Openreach advising fault is still ongoing. Apologies for this.
I will continue to monitor for further updates from Openreach.
Message 25 of 30
Hi Debbie,
I can't make or receive calls; there is no dial tone, just a slightly echoey void.
Nothing has changed on my end.
Kind regards,
Nichola
Message 26 of 30
Hi SunHounD
The fault has now been closed but the line test is still detecting a fault. Apologies for this.
Is the landline working when making calls?
Message 27 of 30
Hi SunHounD
No problem. We will continue to monitor for further updates.
Message 28 of 30
Thank you.
Message 29 of 30
Hi SunHounD
I've completed a line test which has detected a potential line fault so I have escalated this over to Openreach to be investigated by a line engineer.
We should receive further updates from Openreach within the next 48-72hrs.
