Losing Patience with broadband
Mjrichards21
Message 13 of 13
anyone else seem to have this problem
When we first got broadband we where told it was guaranteed to reach every room, 1 month later it stopped reaching one of the bedrooms (this was the reason we left sky) when we rang they said i had to place the TV next to the router bit hard when the TV is upstairs and the only phone line is in the living room.
Told me to buy a WiFi extender done that tv now has Internet
But every few days are skyq boxes are constantly kicked off the Internet
With the message either to reconnect to the main q box sometimes this works sometimes it doesn't or a message about unable to obtain it address
Now I've checked the service status and it says where not receiving the best line speed so ive been in touch with Cs and they where doing something from there end and would take upto 10 days to stabilise and our skyq boxes would no longer keep getting kicked off,
Well now its every few hours its kicking them off and now one of the kids xboxs is doing the same everytime they turn it on its saying connect to network we try that and it comes up about the ip address the only way I'm managing to bypass it is by forgetting the network and re setting it all up again on the xbox
Can anyone help please
12 REPLIES 12
Message 1 of 13
Thanks for confirming. I can see that the fault has been raised to Openreach, please let us know how you get on.
Message 2 of 13
Yes I tried that and then yesterday customer services put them back together
They also made me reset the router as we where getting slow speeds today its even slower 😑
Message 3 of 13
Thanks for the update and I'm sorry to hear this. Did you also try separating the SSID's on the replacement router?
Message 4 of 13
So we recieved the new router set it all up and it didn't change anything, ive now had a sky engineer come out and give us a q booster worked perfectly for 2 days and then it kicked our main q box of again, its also coming up when other things get kicked of the WiFi our router isn't issuing an ip or something along them lines,
I've tried every suggestion I've been given yet none seem to work 😕
Message 5 of 13
Router on the way.
Message 6 of 13
I'm happy to try anything, as at the minute I'm paying for something i can't use
Message 7 of 13
Would you like to try a different model router to see if this helps.
Message 8 of 13
So both are working correctly for all other devices but sky 😡 my sky q box only seems to be able to find the one that says upstairs doesn't show the ssid for downstairs so now its connecting and disconnecting within seconds
Message 9 of 13
I can see you have changed the SSID's.  In one of these there is a space, but not in the other, not sure if you are aware.
Just a suggestion, but when I'm setting things up, I always keep things simple and easy to remember.  The SSID's on my router are Home2 and Home5.
If possible, connect a phone or tablet to each to test it is working correctly.
Message 10 of 13
So ive just changed the ssid and on trying to get an xbox to join 1 of the networks its refusing to let it by saying cant connect and then goes on about my router may not be letting mac in
I've not tried the skyboxes yet so will try that in the morning
Message 11 of 13
Hi Mj,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault and the sync speed looks consistent. Have you tried separating the SSID's?
Split your router's SSID (wireless network name)
Skynet_TX
Message 12 of 13
Hi @Mjrichards21 ,
For one of the TalkTalk OCE's on this forum to be able to look into this you will need to update your community profile to include your name, landline telephone number & alternative contact number. This will allow them to identify you, and they will then be able to have a look at your connection and your router to see if there are any issues.
Then they will hopefully be able to respond to this post within a day or two.
