on 02-05-2022 12:18 AM
For the last 4 days,
I lose connection exactly around midnight and then my speed gets below 40mbps - way down the guaranteed speed. Normally I get around 70-75mbps.
Testing the line from my TalkTalk, opens an issue saying there is a problem with my line. The next morning, I get an email and text message saying that no fault has been found and my issue has been closed to repeat the same again the next day.
Unfortunately, the chat service I am redirected to is always closed at midnight. Can this be looked into, please?
on 03-05-2022 11:17 AM
Hi Yuxel,
I've booked the engineer appointment for tomorrow morning - May 04 2022, AM (08:00-13:00) - please let us know how you get on
on 03-05-2022 10:55 AM
Hi Yuxel,
Thanks for answering the security questions, I've sent you a PM requesting a little more information
on 03-05-2022 10:41 AM
Hi Yuxel,
If you'd like us to arrange the engineer visit can you confirm confirm:
I've sent you a PM to confirm some other details
on 03-05-2022 10:32 AM
Hi Michelle,
I did replace everything for the clean test. I doubt it was the router as it happens between the 10 pm-5 am period regularly now 😞
Yes please, I work from home so a stable internet connection is my top priority.
on 03-05-2022 10:29 AM
Thanks for confirming. I've re-run the line test again now and it's still showing the same fault. If you also replaced the cables and microfilter then the next step will be to arrange an engineer visit to the property. Would you like to go ahead with this and we can confirm some details with you to arrange the visit?
on 03-05-2022 10:20 AM
Hi Michelle,
Good thing I didn't have a chance to send the faulty one back yet. Another router is connected to the test socket currently.
This connected router would not reach the line speeds, that was its fault.
on 03-05-2022 10:07 AM
Thank you. The line test is still detecting the same fault. Do you have an alternative router that you can test with? If not then we can send a replacement router for testing purposes to rule this out. We would also send a router returns bag so that one of the routers can be returned.
on 03-05-2022 09:55 AM
Great, I thought so and am currently connected via test socket
on 03-05-2022 09:53 AM
This is the test socket at the top. You would need to connect the router via a microfilter.
on 03-05-2022 09:50 AM
Hi Michelle,
I have removed the cover and there is only one socket.
Is this it or should I look into other phone sockets at home?
This was my main socket and router was connected since i moved in.
on 03-05-2022 09:32 AM
Thanks for confirming. The NTE55C socket should have a test socket below the bottom faceplate. Would it be possible to connect the microfilter and router at the test socket so we can re-run the line test again please?
on 03-05-2022 09:20 AM
Hiya,
My main socket is master socket 5C, Openreach branded, and has only one socket connection.
I have two other sockets in the hallway again with one connection on each of them.
Connection and speed keeps dropping multiple times when it is close to midnight till early mornings and seems to be more stable during the day
Online for 00:06:23 day(s)
on 03-05-2022 08:46 AM
I'm sorry to hear this. I've run a test on the line which has detected a possible fault towards the property and the connection looks very unstable. Does your main socket have a test socket please?
on 02-05-2022 09:31 AM
Hi @Yuxel your post has been escalated and you should hear back tomorrow when the team return
