Losing connectivity
Cloudy_but_fine
Message 25 of 25
Hello I'm looking for some help.
For about a month we have been experiencing regular internet disconnections (about 10x per day).
In addition our devices are regularly 'losing' each other on the network. e.g iPhone can no longer see Sonos speakers or Valiant Heating Hub.
Finally, today someone rang on the land line and as soon as the phone rang I lost internet connection in the middle of a VC.
Thanks in advance
24 REPLIES 24
Message 1 of 25
Hi Alan
I've checked the connection stats and I can see re connections on the line but the line test is clear.
If the connection is still dropping with the replacement router at the test socket then the only option we have is to arrange another Openreach engineer visit.
Message 2 of 25
We had an engineer on Friday who was very thorough checking everything inside and outside the property. He found no issues with the line at all.
I now have a new router connected directly into the sole entry point into the house with an excellent line into the property and I am still getting dropouts, especially this afternoon.
What is the next step?
Alan
Message 3 of 25
Hi Alan,
I've booked the engineer for tomorrow morning (May 21 2021, 8am-1pm), please let us know how you get on
Message 4 of 25
I'll send you a PM to confirm some details.
Message 5 of 25
Yes please
Message 6 of 25
I'm sorry to hear this and I will take another look now. I've re-run the line test which is still clear. If the connection is still unstable at the test socket with 2 different routers, microfilters and cables then the next step will be to arrange an engineer visit to the property. Would you like to go ahead with this and we can confirm some details with you?
Message 7 of 25
I have left this for a while to compare.
i am still getting dropout on the test socket.
Thanks,
Alan
Message 8 of 25
Thanks for the update and I will pass your feedback on. Please let us know how the stability compares now that the microfilter, router and phone are connected at the test socket.
Message 9 of 25
Thanks Michelle, that helps a lot. I've removed the faceplate and connected to the test socket via a micro filter.
Can I just point out that calling that a test socket is not very good terminology for the lay-person.
Perhaps "plugging in to the internal socket behind the faceplate"?
Message 10 of 25
Hi Cloudy_but_fine,
I've included a Help Article below,
Your guide to main phone sockets
Message 11 of 25
That's the primary one. The wifi and the phone connections combine in the face plate and there is a male connector from the back of the face plate that connects there.
Unless I'm missing something? Previous sockets I've had have two female connectors when you remove the faceplate.
As I see it the faceplate is acting as the microfilter and that socket is the one that is in use all the time
Message 12 of 25
Hi Cloudy_but_fine,
How are you getting on?
Message 13 of 25
There definitely is, right in the top centre between the two screws. You will need a plugin microfilter to connect your router there.
Message 14 of 25
Hi Debbie, I checked before sending you the last reply, but to confirm I've attached a photo with the plate off
There is definately no test socket.
Message 15 of 25
Hi Cloudy_but_fine
This socket should have a test socket, if you squeeze the 2 clips on either side, does the face plate come away?
Message 16 of 25
Hi Debbie, there are no wired connections - everything is wireless and all drops out simultaneously (we get the orange flashing lights on the front of the router)
I don't appear to have a test socket. The socket is a Master Socket 5C and it has an Openreach mk4 face panel on it with separate plugs for wifi and landline. There are no test socket behind the face panel IMG_0297[1].JPG
Message 17 of 25
Hi Cloudy_but_fine
I've completed another line test which hasn't detected any faults but I can see re connections on the line.
Are wired connections also dropping? Is the router at the test socket at the moment?
Message 18 of 25
The router has arrived and I have installed it however the issues still remain. I've had 2 dropouts in the last 30 minutes
Message 19 of 25
Hi Cloudy_but_fine
Debbie 🙂
Message 20 of 25
That would be terrific thanks Debbie!
