Loss of internet connectivity becoming more frequent with HG633 router.
fade2gray
Whizz Kid
Message 10 of 10
I've had the HG633 for about 3 years now and internet connectivity used to drop out every couple of months or so, now it's around every couple of weeks - this happens to all devices, wired or wireless, but I can still ping all devices on the Windows network.
When these dropouts occur, the LED remains solid white and the router's interface claims everything is A-OK across the board but requires a reboot to re-establish an internet connection. I've tried different micro-filters and even left them connected to the test socket but still, the dropouts occur.
Could I try a replacement router - TT are welcome to have this one back.
P.S. At the time of the dropouts the landline is unaffected.
9 REPLIES 9
Message 1 of 10
I think you will need to configure the router manually.
Message 2 of 10
Thanks for everyone's assurance.
Will I be able to import the config file exported from the Sagemcom, or will I need to manually reconfigure the reserved IP addresses for all the various devices I have?
Message 3 of 10
Hi fade2gray
I'm also using the Huawei WIFI hub, it performs really well and I've never had any issues.
Message 4 of 10
@fade2gray Do not confuse "superior" with "more expensive."  😉
Give the Huawei Hub a go and see how you get on. Like Karl, I prefer it to the Sagemcom.
Message 5 of 10
you can, but I find the wireless of the Huawei hub better than the sagemcom and the configuration menu has more options, but it's all down to personal preference.
Message 6 of 10
@Debbie-TalkTalk @Karl-TalkTalk
Thanks for the reply, but I, unfortunately, gave some misinformation in my OP.
The router I am currently using and having issues with is the Sagemcom Fast 5364, the one that you can see the copper colour through the perforations, the HG633 was the router I had been using before being replaced with the Sagemcom when I renewed my contract.
Regarding the Huawei DG8041W, from what I've read the Sagemcom is the 'superior' version of the two hubs that TT provide and in that respect if I return the Huawei unopened and unused, could I have the Sagemcom replaced like-for-like as I have not read anywhere of anyone else experiencing the same problem and suspect it has developed an intermittent hardware fault?
Message 7 of 10
Debbie has ordered the Huawei Hub (DG8041W) for you.
Message 8 of 10
@Debbie-TalkTalk
Thank you - you say a different router as in a different model, if so what model will it be and will I be able to import the exported configurations I have made from the HG633?
Also, can you check the delivery address is correct as TT has got it wrong in the past?
Message 9 of 10
Hi fade2gray
I have ordered you a different router and a returns bag for your current router.
Please allow 24-48hrs for this to arrive. Let us know how the connection compares with this router.
