on 21-05-2022 01:03 PM
Since December my fibre speed has dropped, and from the 54Mbps guaranteed speed, I now am only getting 17.4. Why am I bothering to pay for this increased speed. Trying to contact anyone is a nightmare. Can one of the Mods on here do anything about turning my speed up again, or failing that, give me a live chat link to someone who can.
on 09-06-2022 05:57 AM
Thanks for the update and I'm glad to hear that the speed has improved. I'm just sending you a Community survey via PM.
on 08-06-2022 05:22 PM
Hi Karl. I don't know what you did, but my speed is back up to 53Mbps for the first time since Christmas. Many thanks.
on 08-06-2022 12:23 PM
The profile has increases and I'm showing sync at 58mb, however the line test is still showing a loop fault near the premises.
Is it possible to take all equipment out of the test socket so nothing is connected, then let me know. I can run the test again and see if it still fails with nothing connected. This will rule out any equipment faults etc.
on 08-06-2022 12:04 PM
Hi Michelle.
Micro filter arrived today. Plugged into the test socket, but no marked increase in speed, though it has risen from 19 to 21 Mbps!
on 01-06-2022 12:59 PM
One is on the way.
on 01-06-2022 12:51 PM
Hi Michelle
I suppose that would be the next step to trying to sort out this problem. Thank you.
on 01-06-2022 06:43 AM
Would you like us to send you a microfilter? This is just so we can confirm if there is any improvement in speed at the test socket and to rule this out.
on 31-05-2022 05:37 PM
I do not have any filters in order to try the master socket, as I have no need of them with the pre-filtered socket. I do wonder if, as I am getting 18Mbps to the router, whether it is the router throttling the speed.
on 31-05-2022 07:07 AM
Hi Acebass
There should be a test socket underneath the faceplate. You would need to remove the lower section of the faceplate and then connect the router and filter directly at the test socket.
on 30-05-2022 10:31 PM
The main socket looks like the one labelled FTTC.
on 30-05-2022 01:30 PM
Can I just confirm, does the main socket look like the below please?
Your guide to main phone sockets - TalkTalk Help & Support
on 30-05-2022 01:27 PM
Not sure where my replies to you keep going. Sorry if you get multiple replies. I cannot see any test socket.
on 30-05-2022 06:59 AM
I'm sorry for the delay. Did you see my last post in regards to the test socket?
on 28-05-2022 12:28 AM
Hi Michelle. Any movement on this fault please?
on 23-05-2022 10:09 AM
I've run a test on the line which has detected a possible fault towards the property. Does the main socket have a test socket please?
on 23-05-2022 10:04 AM
It is now Michelle, I have just updated it.
on 23-05-2022 07:28 AM
Is the telephone number in your Community Profile correct? Please do not post any personal information on the Community.
on 22-05-2022 12:57 PM
Thanks for that, it does seem low. I will get TalkTalk support on this forum to investigate the issue for you.
on 21-05-2022 04:52 PM
Downstream line rate (kbit/s):19999
Upstream line rate (kbit/s):11993
21-05-2022 03:44 PM - edited 21-05-2022 03:46 PM
The HG635 is no longer a current router, as it is quite old.
The speed test is not guaranteed as that can be affected by the device, the speed that is guaranteed is the one recorded by the router. On the HG635, please log into the router & use the "Check My Internet Connection Status" from the router's home screen. In there look at the Upstream & Downstream Line Rates. What speeds do they display?
