MS Remote Desktop over OpenVPN
gh2609
Message 28 of 28
Here’s the problem:
I have a Sagem router (TalkTalk supplied) and via WiFi connection, trying to use MS Remote Desktop over OpenVPN with an iPhone. This works very well via a Windows 10 laptop, desktop and Android tablet, but will not work with the iPhone. I tried three separate iPhones, all of which will connect to OpenVPN server using iPhone OpenVPN client, but then get no response trying to connect using MS Remote Desktop client.
The iPhones will however connect through OpenVPN and MS Remote Desktop via a cellular connection.
As a further diagnostic step, I also temporarily changed router to one previously supplied by TalkTalk (D-Link), but this gave exactly the same result.
I even tried to connect using iPhone at another property using TalkTalk, but this also failed.
In every case using the iPhone, a ping or traceroute to the Remote Desktop host returns no response, even though an OpenVPN connection has been established.
Any ideas will be much appreciated.
27 REPLIES 27
Message 21 of 28
Hi @gh2609
Thanks, Glen for confirming this. I assume that iPhones still do not support any kind of pcap capture technology, so there is no way I can find out what is going wrong. All I can therefore suggest is that this is passed over to the TalkTalk products team for testing.
@Michelle-TalkTalk please can you arrange this?
Message 22 of 28
Hi Keith,
Thank you for offering to help. To summarise, the details below show the connectivity issues. The OpenVPN server is located at work and all relevant ports ports have been confirmed as open.
Connection required is to use MS Remote Desktop over OpenVPN.
Any iPhone
Using TT Fibre+Router+WiFi.
Using TT Fibre+Router+Ethernet.
Using Virgin Fibre+Router+WiFi.
Using cellular network.
Android phone
Windows 10
Using cellular (tethered).
So the issue appears to be associated with a combination of iPhone through a TT fibre and router.
Glen
Message 23 of 28
Hi @gh2609
@Michelle-TalkTalk has asked me to help you but I do not have any Apple products to test with.
However, I might be able to help on a more generic basis but first I need to understand better your scenario.
Is open VPN installed as a client on the working desktop, laptop, Android, is it also installed in the same manner on the iPhone?
Where is the PC you are trying to RDP into, is this at work or at home? Where are the iPhone, laptop, desktop & Android when you try to RDP into this PC?
Message 24 of 28
@KeithFrench - Is this something that you would able to offer any advice on?
Message 25 of 28
Thanks for the update.
Hopefully the OCE may have a solution for you.
Is there an Apple forum where you can also ask in case someone there had a similar problem?
Message 26 of 28
The scam filter is off and has been so for at least the past year.
I have narrowed down the problem to a combination of using an iPhone and TalkTalk. The MS Remote Desktop over OpenVPN works fine with Windows 10 and Android using TalkTalk.
Further to my earlier post, I have successfully connected to the MS Remote Desktop host with iPhone using a Virgin Media fibre connection and WiFi. As soon as I use the same iPhone over a TalkTalk fibre connection, the MS Remote Desktop client will not connect.
So still puzzled as to what the problem is.
Message 27 of 28
Have you tried turning scam protection off?
If you go to my account, you can turn this off there.
To do so:
1 Log in to MyAccount
2 Select My Services
3 Select View HomeSafe settings
4 Select OFF and confirm when you see the pop-up window
You may also need to disable any pop up blocker you may have installed
Good luck.
