Minimum speeds
ntrbower
Message 3 of 3
I'm on Fibre35 - what are the minimum upload and download speeds I should be exceeding?
Message 1 of 3
Each connection is different and speeds are determined by the distance from your local cabinet.
In your case, the max estimated speeds are 11.5mb down and 2.1mb up.
martswain
Message 2 of 3
Look at your order confirmation or the information in Service Centre.
It depends on the length and quality of your line from your home to the fibre cabinet.
TT do not guarantee upload speeds, just a minimum guaranteed download speed.
Staff can also check if you add your landline number to your community profile, do not post personal info here !
