Moving House - can I get Fibre 65 but keep Sagecom F5364 router
richardlister
Whizz Kid
Message 14 of 14
about to move and wondering whether to switch providers but checking best TT offers.
I can get 65 where I'm going but TalkTalk online move process only offers Fibre35.
I'd like 65 and to keep my SagecomF5364 router.
Are both possible?
thanks
Richard
Richard Lister
13 REPLIES 13
Message 2 of 14
@Arne-TalkTalk yes thanks. Extremely helpful. Uk based. Which helps with clarity.
I await it all going smoothly now.
thanks
richard
Richard Lister
Message 3 of 14
Message 4 of 14
I suggest you get in touch with the Home Move team directly to clarify what's what, call 0345 172 0088.
Message 5 of 14
I've gone on as new customer and got offered 65 plus various comparison sites for that address all say 65!
Richard Lister
martswain
Message 6 of 14
If you are only being offered Fibre 35 at the new address it is likely that the line to the cabinet is so long that it cannot support Fibre 65 speeds.
As for the two HUBs, if you get a new one as part of the move, keep it as a spare.
Message 7 of 14
@richardlister It is marketed as such, but both have identical specifications. It may just be that the WiFi Hub black was included on the order automatically, but doesn't in fact arrive if they establish that you already have a suitable device.
Message 8 of 14
@paulshent - thanks but I thought the Sagecom F5364 was superior according to TT site plus costs more if u are buying them.
https://accessories.talktalk.co.uk/?category=Routers
Richard
Richard Lister
Message 9 of 14
You can use the router you prefer, you don't have to use the new one if one is sent
paulshent
Message 10 of 14
Take your router with you.  Just ensure your new line can support fibre 65 over 35.
Otherwise the standard router is the sageMcom.
I am sure the Loyalty team or an OCE will verify my comment
Message 11 of 14
Yes but the online move process says they are including a new black router - which is lower spec'd than the one I have? Just wondered if there was a technical reason for the router swap if I go up to 65mbps?
thanks
R
Richard Lister
martswain
Message 12 of 14
@richardlister when you move home you are expected to take your router with you !
Chris-TalkTalk
Message 13 of 14
Hi Richard,
If you speak to our loyalty team they should be able to help. There are details how they can be contacted here
