My Faster Fibre Broadband is running at about 1Mbps
Alexsandr
Message 19 of 19
I've been struggling with my broadband for the last 7 - 8 weeks (ever since the price went up). Some of my devices lose connection randomly. I get buffering when trying to stream. I've run out of ideas on how to improve this. I've just run a speed test with three different websites and they report 0.1, 1.84 & 0.34 Mbps download. I often end up turning my router off and then on again. Previously I have been able to chat online with a representative but that option seems to have been removed (I guess due to the Pandemic). I was on a very important Zoom meeting yesterday and I kept getting pop up messages about my connection.
I'm at my wits end, any good advice would be much appreciated.
18 REPLIES 18
Message 1 of 19
Tests are showing a loop fault in or near the property.  The next option is for an engineer to visit.
I'll drop you a PM to confirm some details.
Message 2 of 19
Hi. The replacement router is now installed and active. I've just carried out a speed test (via three different test apps) and the download speed was reported at about 46 Mbps
Message 3 of 19
OK, No Problem 🙂
Message 4 of 19
OK, thanks. I'll reply to this message when I've installed the replacement unit. Thanks Ian
Message 5 of 19
I'll get a different model router to you so that hardware issues can be ruled out.
Message 6 of 19
Sorry, I only have the one router
Message 7 of 19
Hi Alexsandr,
Thank you. I've re-run the line test again now which is still detecting a loop fault. Do you have an alternative router that you can test with?
Message 8 of 19
Done
Message 9 of 19
Hi Alexsandr,
Thanks for confirming. Would it be possible to connect the microfilter, router and phone at the test socket behind the faceplate so we can re-run the line test again please?
We're currently investigating the email issue this morning and updates for this will be updated on our Service Status Page as soon as we know more.
Message 10 of 19
Hi Michelle. It's the NTE 5C. Speed about 25Mbps this morning. Mail apps showing cannot connect to server. Everything running very slow at the moment. Regards Ian
Message 11 of 19
Hi Alexsandr,
I'm sorry for the delay. Can I just confirm, does the main socket look like the below?
Your guide to main phone sockets
Message 12 of 19
Update from my earlier message, best speed so far this evening has been 17.2 Mbps. Been trying to book a return flight for an hour, eventually gave up. will try again tomorrow.
Message 13 of 19
Hi Michelle. I've just logged in to see if you replied to my earlier message but I can't see it. Not sure what happened there. So to repeat my previous reply, the main socket has only one connection point on the outside so unless the test socket is inside I would say no. The main socket is badged BT Openreach. It has a filter connected from which two leads are connected, one to my router and one to my phone via a CPR CallBlocker. My router has two connections, one to my smart TV and one to my YouView box. Regards
Message 14 of 19
Hi Alexsandr,
I'm sorry to hear this. I've run a test on the line which has detected a possible loop fault. Does your main socket have a test socket?
Message 15 of 19
So are these over the wired or wireless connections. When the speed goes slow, what does the router show then?
Message 16 of 19
I've just repeated the three speed tests and it's currently reporting 60.6, 69.6 & 71.72 Mbps.
I've carried out these three test occasionally over the last few weeks, usually when I'm having problems, and the results are usually very low but then I have also had, as shown here, some good results. Why is there such a variation and why does it seem to happen regularly ?
Message 17 of 19
Hi Keith.
My router is a FAST5364-3.T8
The dashboard shows 80 Mbps Download & 20 Mbps Upload
I have two wired connections which are my TalkTalk tv box and my television.
I very rarely use the TV direct connection but I have been getting some odd things happening with my TalkTalk box i.e. I lose connection from the handset and only rebooting the box resolves this. I have also had what looks a bit like buffering when using the TV apps.
Hope that info helps.
Message 18 of 19
I can help, but please can you elaborate by answering these few questions:-
2. If you log into the router what speed does it show there (normally in the initial dashboard, but not knowing the router that you have, I cannot be more precise)?
3. If you have any wired connections, are they affected in the same way as wireless ones?
