My internet is down in york
Ravenrob
Message 12 of 12
Is anyone else having problems in Huntington york?
11 REPLIES 11
Message 1 of 12
OK thanks, could you take a look at our UFO support hub, if you then still need assistance can you contact our UFO support team, they'll be able to help
Message 2 of 12
Yes I’m on ufo and the talk talk landline is also down
Message 3 of 12
Hi Ravenrob,
I'm sorry but the landline number that you've provided isn't bringing up any details. Do you have our UFO service?
Message 4 of 12
According my account details this is my land line however it will not dial out it’s also down..
I can’t do test of line as the internet is down.. when I try and so the test with mobile data.. it crashes.. I have tried the usual on and off with the router and wall box
Message 5 of 12
Hi Ravenrob
Have you added the correct landline number to your Community Profile?
Have you run a test using our Service Centre
Message 6 of 12
Hi Debbie,
added information requested
Message 7 of 12
Hi Ravenrob
  • Name
  • Telephone number
  • Alternative contact number
Message 8 of 12
P.s i cant troubleshoot my line as internet is down.. I’m connected now through mobile data
Message 9 of 12
My internet is still down this morning,
on my modem on the wall all lights are flashing green except LOS which is flashing red,
my router has orange light not white.. when i reset the router flashes white and orange then goes constant orange..
and when i try to call out on my phone a voice says calls can not me made from this phone..
and my bill is paid
Message 10 of 12
The router is orange, the modem has a flashing red light and the phone says can’t make calls
Skynet_TX
Message 11 of 12
Hi @Ravenrob,
What are the light(s) showing on your router ?
It would be worth going to the Service Centre to ‘Run a live connection test’ on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
Then they will hopefully be able to respond to this post within a working day or two. You may get faster support from the live chat or by phoning up during opening hours.
