My router stopped working after power cut
sburd
Message 5 of 5
We had a power cut and now when I boot my router I can't get a WiFi signal. I have tried resetting both the router and my devices.
4 REPLIES 4
Message 1 of 5
Hi sburd
I will send you a replacement router.
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 5
Hi @sburd,
If a factory reset hasn't got it working again then that may indicate the router has developed a fault. If you log into the router does it give any indication if the wireless is active or disabled ?
Message 3 of 5
Thanks, but already tried that. Doesn't work.
martswain
Message 4 of 5
Press the RESET button for 30 seconds.
