on 12-03-2021 10:24 PM
Hello, i’ve spoken to multiple talktalk employees about this situation which has been going on for over a week now, my speeds through a time period of 2/3pm to 1am are just terrible i’m getting speeds of 2mbps i’m guessing even if I was on the slowest broadband speed I would get more than that, but i’m not i’m on Fibre 65 where my minimum speed says I should be getting 64.1mbps. It’s really infuriating now as i’ve spoke to people through live chat on twitter direct message etc, all I keep getting asked is if they can run checks they run the checks and come back to me and tell me that the line is fine on their end to the router, i’ve literally tried, searched and done everything possible to get my internet speed to pick up during the times i’ve set and nothing at all has worked, my partner works from home and the internet doesn’t help that situation, I can’t play on the PlayStation whatsoever, I can’t really search things on the internet as it takes about 5 minutes to load when I press enter and all it feels like is talktalk are leaving me in the dark with whatever the situation is.
on 17-03-2021 06:37 AM
Hi JoeMBell
Thank you 🙂
on 16-03-2021 03:04 PM
on 16-03-2021 01:43 PM
HI @GStanley
Please can you create a new topic on the Community, we can then look into this for you.
on 16-03-2021 01:26 PM
Hi I have the same problem with Wifi. I find it is Okay on a morning , but evening it is unusable. I traced the problem to the Wifi channel. The new TT router automatically checks for the best channel (always 11). I can change it in the router settings and resolve the problem but it reverts back to channel 11. I called Talktalk support and explained the issue and asked them to disable their remote management tool "Wi-Fi Optimisation. As the support engineer didn't really want and said it looks for the best channel.
I bypassed the problem by adding an old router to the Talktalk router and used its wi-fi set to channel 1. Problem solved. Bit annoying as I had to buy the new Talktalk router. Maybe I should return the new one and ask for my money back.
on 16-03-2021 12:31 PM
Hi JoeMBell
Thanks for your reply. Please let us know how you get on.
on 16-03-2021 11:28 AM
Hiya Debbie, last night at about 6 I was getting about 65+mbps today right now i’m getting around the same but last nights really surprised me as that’s when the struggle has been happening. I was going to add a picture but because i’m on iPhone I can’t 😂 i’m going to give it a couple more days to see if the line is consistent then i’ll cancel my engineer.
on 16-03-2021 10:34 AM
Hi JoeMBell
I'm so glad to hear this. What speed are you now receiving?
on 16-03-2021 10:13 AM
on 16-03-2021 08:36 AM
Hi JoeMBell
Your line is currently in sync at 78mb.
Please can you power down the router for a full 30 minutes and then run a speed test?
on 15-03-2021 11:32 AM
on 15-03-2021 10:45 AM
Hi JoeMBell
Is this an Openreach engineer visit?
on 15-03-2021 10:18 AM
on 15-03-2021 10:08 AM
Hi JoeMBell
I've completed a line test which hasn't detected any faults.
Would you like me to send a different router for testing to see how the connection compares?
on 13-03-2021 10:28 AM
Asit affects wired connections as well, I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
on 12-03-2021 11:01 PM
on 12-03-2021 10:37 PM
on 12-03-2021 10:30 PM
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
