on 12-04-2019 09:32 PM
Just had my connection upgraded to fibre broadband. Download speed now 10Mbps before I was getting 15Mbps. My upload speed has increased from 1Mbps to 5Mbps.
Not what I was expecting or paid extra money for?
on 30-04-2019 12:29 PM
OK thanks. Can you just confirm that when you disconnected the hubs you rebooted the router afterwards
on 30-04-2019 10:49 AM
One socket. I have a lights and heating hubs connected to the router. Before you ask I have tried disconnecting those and it makes no difference.
all this started when I upgraded from TalkTalk fast broadband to fibre broadband.
on 30-04-2019 09:39 AM
HI jfmarkham
How many telephone sockets do you have? What other devices do you have connected in addition to your router?
Does your master socket have a Test Socket?
on 30-04-2019 07:12 AM
I'm still getting between 12-15mbps download and 5mbps upload. Wireless speedtest.
Still nowhere the minimum speed promised for fibre broadband.
Streaming videos continually stutter.
Plus we have no tv and movie boosts working. Whereas before upgrade they did.
I wished we had not upgraded from fast broadband to fibre as I am paying more money for less.
What is next step as it cannot go on like this.
on 30-04-2019 07:07 AM
Hi jfmarkham,
Ok thanks for confirming this. I've re-checked the connection stats and the connection looks stable at the moment. What speeds are you currently receiving? Are you running the speed tests wired or wireless?
on 29-04-2019 05:52 PM
on 29-04-2019 04:14 PM
Hi jfmarkham
There are re connections showing on the line, is the connection dropping or have you rebooted the router?
on 29-04-2019 04:05 PM
on 25-04-2019 11:46 AM
Hi jfmarkham
Thanks for your reply. If the landline is now clear of noise then we can focus on the BB fault.
on 25-04-2019 10:36 AM
have tested line, seems fine.
still getting 12mbps download and 5mbps upload.
also just noticed after switching to fibre I no longer have my extra tv and movie boosts working. There is an error code IPC6023z
how can we get this sorted, I am now paying extra for fibre that doesn’t work and now my boosts don’t work.
i wish I had never upgraded!
on 22-04-2019 09:12 AM
Hi jfmarkham
Do you have a corded handset that you could test with?
It would be worth testing the phone at the test socket, with a microfilter and with the router removed from the line. This will help rule out the router causing the noise.
on 22-04-2019 09:03 AM
Cordless phone
Yes I used a microfilter.
No I did not remove router. Nobody told me to so why would I know it was supposed to?
on 22-04-2019 07:56 AM
Hi jfmarkham
You should not hear static noise on the line. Did you test with a corded or cordless handset? Did you also use a microfilter and test with the router removed from the line?
on 21-04-2019 02:20 PM
Hi I have rung out from the line to my mobile and the other way. The line I quite clear but with some static.
I am still getting download speeds of approx 12mbps and upload of 5mbps.
So upload is 5x faster with the fibre line but my downloads are the same if not slower.
Nowhere near the guaranteed download speeds mentioned by TalkTalk and not what I am paying for.
on 17-04-2019 08:21 AM
Hi jfmarkham,
Ok thank you.
on 17-04-2019 07:49 AM
I'll see what I can do.
on 17-04-2019 07:20 AM
Hi jfmarkham,
Would it be possible to borrow a phone for testing purposes to rule out any issues with the voice service?
on 16-04-2019 07:10 PM
The OCE has already tested the line remotely.
Now YOU need to plug in a handset and see if you have a dial tone, any extraneous noise on the line and the ability to make and receive calls.
on 16-04-2019 07:02 PM
Hi, thanks for reply. How do you plan to test the line. John.
on 15-04-2019 08:46 AM
Hi jfmarkham,
I'm sorry for the delay. I've run a test on the line which has detected a potential voice fault. Would it be possible to test the voice service for any noise on the line/no dial tone as a voice fault can affect the broadband connection?
