New Talktalk router connectivity
MarkP5
Message 11 of 11
Hi I've had two Google points on my Draytek130 working fine for a few years, I lost network during the infrastructure cable upgrade yesterday, and now can only get network installing the new talktalk router, and unable to connect my Google devices, would appreciate some help or direction.
Mark Porter
10 REPLIES 10
Message 1 of 11
Thanks for updating your profile Mark - look forward to hearing how you get on with Keith's suggestions
MarkP5
Message 2 of 11
Oh OK, I'll try it and let you know, much appreciated.
Mark Porter
Message 3 of 11
That is because Fibre 35 & 65 is FTTC so the service is delivered from the fibre cabinet via the copper cables to your home. If your new TalkTalk works & the Draytek doesn't, it makes me wonder if the Draytek has an inbuilt modem that is compatible with VDSL2 fibre. It might if you do a factory default of the Draytek's configuration.
MarkP5
Message 4 of 11
Yes that's their plan but I still have a pair of 60 Yr old copper  wires from the street cab so don't know how that's gonna work??
Mark Porter
MarkP5
Message 5 of 11
All done.
Mark Porter
Message 6 of 11
I assume then that you have just gone over to fibre from the old ADSL? Is the modem in your Draytek router VDSL2 compatible for TalkTalk fibre?
Message 7 of 11
OK thanks Mark, could you update your profile please
MarkP5
Message 8 of 11
Hiya no residential, this is the new fibre 35 rollout, in progress, was more than happy with my own system but lost network during their upgrade work yesterday, so installed their kit but can't get my Two devices onto the network and one of them is for the office at the end of the garden.
Mark Porter
Chris-TalkTalk
Message 9 of 11
Hi MarkP5,
Could you please answer Keith's question and can you update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 10 of 11
What exactly was this upgrade, are you a TalkTalk Business customer?
