on 06-06-2021 06:15 PM
I get fibre 500 installed on the 14th and when I originally ordered this on the phone the staff member advised me I would get a new router before the engineer came to install the fibre. However I received an email from talktalk saying that they can see I have a WiFi router and the engineer will use that to install the broadband.
I'm confused to which one is correct, if I don't need a new router fair enough. I just don't want to find out on installation day that I've got the wrong equipment
on 07-06-2021 08:30 AM
The number is 03451720074
on 07-06-2021 08:27 AM
@Paulefc , OK, could you let me know the number either here or by Private Message.
I keep a list of useful numbers just in case I can help other members.
on 07-06-2021 08:23 AM
on 07-06-2021 08:11 AM
on 06-06-2021 09:53 PM
The OCEs on this forum do not normally have access to future fibre currently, although that may change at some point.
on 06-06-2021 07:17 PM
@Paulefc I am only a customer and not sure if staff here can deal with router requests for Future Fibre.
I believe there is a dedicated number for the Future Fibre team, which hopefully you have in your order documentation, so best to call them as the other call centres do not seem to be very knowledgeable on Future Fibre.
Staff will be back here tomorrow but you may not get a reply for a day or so due to the weekend backlog.
A Community Star may have better info, @ferguson or @KeithFrench , any ideas ?
on 06-06-2021 06:42 PM
Okay thanks. Will I have to telephone them tomorrow or will the staff on here be able to organise the new router?
on 06-06-2021 06:39 PM
@Paulefc you need a new router.
Your current model only has 100 Mbps LAN ports so that will severely limit you for wired connections on Fibre 500.
From what I can find, it does not have a WAN port either which is required for the connection to the modem that will be fitted.
on 06-06-2021 06:34 PM
It's a D-link model Dsl 3782 super router
on 06-06-2021 06:26 PM
Hi, I had an engineer out last week as I've been having probs with my phone line and WiFi speed. He said my router, Huawei hg633, is out of date and I should have got a new one when I upgraded. Insist on a new one if you've had yours a while.
on 06-06-2021 06:22 PM
Exactly what model router/HUB do you have ?
