New fibre 35 connection speed has halved, overnight.
8 REPLIES 8
bukey
I had fibre 35 connected yesterday and I tested the speed on the talktalk speed checker. Great. my speed was showing 36.9 Mbps consistantly.
I checked today and it was sometimes 20 Mbps  to sometimes 15 Mbps.  So overnight it had dropped to half what I was getting on installation day.
My service performed brilliantly when it was at 36.9 Mbps, so why has the speed halved?
I can live with this but I am paying extra for somehing I am not getting.
What is the answer?  I would like to pay less, as I'm paying an extra £6.50 per month for agreeing to fibre.
I have attached my speed test results.
regards.
Skynet_TX
Hi @bukey,
If you check the sync speed of your router, has that also dropped, or is that still up at around 40mbps ?.
OCE_Debbie
Hi bukey
I've checked the connection stats and the line is in sync at 39.2mb.
Please can you power down the router for a full 30 minutes and then run a speed test following this?
bukey
Hi,  thanks for responding.
I checked and and it is very close.  I am getting the faster speed now on the speed checker, so maybe it was just a temporary thing.  Fingers crossed.
bukey
@OCE_Debbie
I am getting the faster speed now on the speed checker, so maybe it was just a temporary thing.  As I was test on the wi-fi connection, maybe at the time there was interference.
I will continue to monitor it.
Thank you for your efforts.
bukey
@Skynet_TX
OCE_Debbie
Hi bukey
How has the connection/speed been since your last post?
bukey
@OCE_Debbie
Hi,  It's been quite good.
It played up the other day, the TV box was buffering and picture awful on catch up.  I had a speed of 1.2 Mbps, but after switching everything off, including router, and restarting, it came back as somewhere in the 30's again.
Occasionally, especially after a speed check to repeat, I get a socket error message, whatever that means.   It is not causing any annoying problems though.
Thanks for enquiring,
regards.
OCE_Debbie
Hi bukey
If you do continue to experience this issue then please let us know.
