New router - WiFi not showing up on any devices
Feebaldwin
Message 9 of 9
I had my talk talk fibre installed today. The router turns on and has a white light as if it’s connected to the internet. But there is no wifi network with its name on any of my devices, so I am unable to connect to it.
8 REPLIES 8
Message 1 of 9
I'm glad to hear this and thanks for the update 🙂
Feebaldwin
Message 2 of 9
Hi Debbie,
I have just set up the new router and it’s working! Thanks so much for sending the replacement.
Sophie
Message 3 of 9
Hi Feebaldwin
Feebaldwin
Message 4 of 9
Good morning @Debbie-TalkTalk
Yes I have tried resetting twice but still unfortunately nothing is showing up!
Thank you
Message 5 of 9
Hi Feebaldwin
Have you tried a factory reset? If you are still experiencing this fault then I will send a replacement router.
Skynet_TX
Message 6 of 9
Yep, you would have to use a device that was connected to the router using an ethernet cable to be able to log into the router if the Wi-Fi is not working.
If you don't have a device you can connect 'wired' then you could just try a factory reset of the router by holding in the reset switch on the back for over 10 seconds, just to see if that helps.
Feebaldwin
Message 7 of 9
Thanks. Unfortunately when I try to put that link in my browser I am unable to open it. I think this is because I can’t connect to the wifi network as it is not showing up. I suppose I’ll speak to the team tomorrow! Thanks
Skynet_TX
Message 8 of 9
Hi @Feebaldwin,
Can you browse to http://192.168.1.1/ and log into the router. Once logged in can you check to see if the Wi-Fi network name is showing as the one you are expecting, and check if the Wi-Fi is showing as enabled or disabled, if it is disabled then try to enable it, if it still won't enable then try doing a factory reset of the router by holding in the reset switch on the back for over 10 seconds. If it is still disabled then it may be that you have a faulty router, the staff here would be able to help with that when they are back tomorrow.
