New router not connecting
Kennytheviking
Message 36 of 36
I've just joined fibre and tried to set up my new router today which is the start date. It has been on for 3 houra now and the light on the front is still flashing orange and white. I've looked on the router set up page on the website and I've followed everything and it hasn't helped at all.
Could you please help me get this sorted? Thanks
35 REPLIES 35
Message 1 of 36
Glad all is working.
Kennytheviking
Message 2 of 36
Sorry for the late reply, I have been at work all day.
Thank you for all of your help, I have come home to a static white light 🥳
Message 3 of 36
Kennytheviking
Message 4 of 36
Hi Michelle
Yeah sure, I'll give that another try.
Message 5 of 36
I'm sorry to hear this. I've completed a radius re-sync. Could you try powering down the Wifi Hub for a full 30 minutes and then try and re-connect again please.
Kennytheviking
Message 6 of 36
Morning
Disappointingly no change over the weekend. My sky router works perfectly but the TT WiFi hub is still just showing a static Amber light.
Message 7 of 36
I'm sorry for the delay in getting back to you. I've run a test on the line now which is clear. How are you getting on since your last post?
Kennytheviking
Message 8 of 36
Great, thank you for you help and advice. I will try the service centre again and see what happens. If not, I'll give them a call tomorrow.
Cheers
Skynet_TX
Message 9 of 36
Ok, so the fact that it has made it past the flashing amber/white and got to static amber would probably indicate that the router has successfully synced, but it is not able to authenticate onto the TalkTalk network.
It would be worth going to the Service Centre to run a connection test on your line as occasionally this can give things a kick and allow the router to authenticate.
If that doesn't help (or it it detects some issue) the staff on this community won't be around until Monday now, so you may get faster support by using the live chat or calling customer services on 0345 172 0088 over the weekend, however the staff here should respond to this topic early next week to help if you are still having issues.
Kennytheviking
Message 10 of 36
I received my new router today, set it up and it's reacting very differently to the old one but still no luck.
The old one constantly and rapidly flashed orange and white/blue. This new one flashes Amber, then flashes Amber and white alot slower than the old one and now it is just a static Amber.
I have done a factory reset, turned off for 30 minutes and disconnected all the wires and reconnected them and the exact same has happened. It has now been on static Amber for 40 minutes with no change.
Could you help me please?
Message 11 of 36
Kennytheviking
Message 12 of 36
Ok, thabk you Debbie.
I'll be in touch in a few days
Message 13 of 36
Hi Kennytheviking
Thanks for trying this. I have a different router on the way for you.
Please allow 24-48hrs for this to arrive. Let us know how the connection compares with this router.
Kennytheviking
Message 14 of 36
Hi Debbie
I've just completed the factory reset and plugged it all back in and it's still flashing white and Amber.
Message 15 of 36
Hi Kennytheviking
The fibre order has completed. Could I just ask if you can factory reset the WIFI hub using the pin hole reset for ten seconds and then try and connect again with this router?
Kennytheviking
Message 16 of 36
I'm asking because Chris asked earlier if I had another router I could test with. I have plugged my sky router back in and it works. So I was wondering if it hadn't been changed over to fibre at the cabinet yet and that may be a reason for the problem with the new TT hub?
Message 17 of 36
Hi Kennytheviking
To use a non TT router, further information can be found here
Set up a non-TalkTalk router
The WIFI hub will work fine with a fibre connection. Would you prefer to try and set up your own router first before we send a replacement for testing?
In regards to the cabinet, the engineer completes work to change the connection over from ADSL to fibre.
Kennytheviking
Message 18 of 36
If you think that the issue is the router then yes.
Does something need to happen at the cabinet to change from normal broadband to fibre broadband? Or are all routers capable of using both no matter their age? I'm only asking as my sky router that works is 7 years old.
Message 19 of 36
Hi Kennytheviking
Would you like me to send another TalkTalk router for testing?
Kennytheviking
Message 20 of 36
It's a Sky router. Model: SR102
The one you sent was the WiFi hub
