New talktalk hub problems
Smifo
Message 38 of 38
Hi all
I go fibre broadband about 6 months ago approx. Great for a few months, then very slow and constantly disconnecting from the Internet. Had openreach out n it was apparently the router. Received a new router, great for a month or two, now very slow and dropping out a lot.
Is there any issue with the new sagemcom 'game changer' hub? Are other people experiencing problems like this?
Any feedback much appreciated.
Cheers
Ian
37 REPLIES 37
Message 21 of 38
Is it possible to send an alternative make of router?
Message 22 of 38
Hi Ian
I can send another router for testing if you would like to test this first?
Message 23 of 38
Hi Debbie
If that's the best route to go. I'm baffled as to why the replacement router seemed to solve the problem for a month or six weeks though.
Cheers
Ian
Message 24 of 38
Hi Smifo
I've completed a further line test which is still detecting a possible fault. As you have recently tested with a different router then I can raise this straight over to our Network Team. Would you like me to arrange this?
Message 25 of 38
It's now connected via the test socket using a new filter.
Cheers
Message 26 of 38
Hi Smifo,
Thanks. Please let us know once the router is connected at the test socket and we can re-run the line test.
Message 27 of 38
OK, let us know when you have connected at the test socket so that the OCE can run their checks again.
Message 28 of 38
OK cheers, I'll try that tomorrow, I'm at work now. Ta
Message 29 of 38
If you can connect at the test socket again for now then the OCE may be able to narrow down whether the issue is internal, or external.
Message 30 of 38
No noise on the landline. Have previously tested socket. Openreach tested everything before, only a couple of months ago.
Message 31 of 38
Does anyone think this could be sorted by sourcing a different router?
Message 32 of 38
Hi Smifo
Thank you for updating your Community Profile.
I've completed a line test which has detected a possible fault. Are you experiencing any faults with the landline service when making calls? (noise on the line)
Is the router currently connected at the test socket?
Message 33 of 38
Hiya, and ta for your reply
No I don't use a vpn. Just standard set up.
valleyboy1975
Message 34 of 38
hi mate,
you dont use a vpn by any chance?
i did, uninstalled it and the talktalk fibre worked fine!
Message 35 of 38
Hi Smifo
Message 36 of 38
Message 37 of 38
Hi Smifo
